I have been using the whiteline bars, but I'm thinking about either switching back to standard ones, or possibly some cusco ones. the whiteline ones are pretty heavy and I wasn't quite 100% keen on the fitment. not sure on the size of the stockies, someone out there must know!
Standard GTR bars are hollow, so outside diameter is a meaningless comparison without allowing for the wall thickness. We run 24 mm solid front swaybars on R32GTR's with 5 settings of adjustment per arm in combination with a 24 mm rear swaybar with 3 setting of adjustment on the rear. I would always recommend using the standard front drop links on a road car. For a track car we use an adjustable length spherical link kit as it enables us to corner weight the car without preloading the swaybars. As always spherical bearings are a serviceable item, even the dust boot covered ones need greasing regularly and change the sphericals usually once per seqason of racing.
Link to the R32GTR Group Buy including swaybars;
http://www.skylinesaustralia.com/forums/in...showtopic=87521
Cheers
Gary
yes but I am still interested in what the standard diameter is...
That's fine, but you would still have to know the relative stiffness increase over the standard bar. any logical person would say, ok here i have a standard swaybar (be it hollow or solid) - what is my zero setting - ie the factory n/mm rate? Then from there, you can say a solid bar of Xmm will have a n/mm rate, which is XYZ % increase over the factory rate. You wouldn't just throw the stock one in the bin and "suck it and see" by throwing on different size sold bars until you get it right. That's not logical.
Standard drop links may be fine, but my issue is that my "Group Buy" bar is contacting my front drive shafts, and I've been told by the suspension shop that I need longer links. I haven't seen where this is contacting, but as the suspension shop installed it all, i am inclined to believe that it's been done properly. Now seeing that it's unlikely that the bar has been installed incorrectly, the two scenarios are
1. the bar is faulty in design/manufacture or both
2. the factory drop links are not appropriate for this bar, and the bar should come with appropriate links
Has anyone else had this same issue?
Hillbilly! You should have rang me... Odds are it will be the links and where they have set the bar to. My issue with sump damage seems to have been link related. I used the std ones which were too short. Even with longer ones i dont think i can practically use the softest settings are the resulting angle is a little too extreme. I need to grab some longer ones and that should fix my headache. Maybe we grab 4 or so.
Who is doing the work, Centreline, Techsport? Should not be that difficult to test the difference in swaybars, they may even have soem std ones laying around
The standard R32GTR hollow swaybar is equivalent to a 20.5mm sold bar, so a 22 mm bar is an effective rate increase of 30%, a 24 mm bar is 85%. That's not allowing for the vertical blading of the arms on the adjustable bars which adds further to the rate as it reduces the flex in the arms. On the anti roll rate comparitor the 24 mm adjustable bar gives around 90%, 96% and 103% increases over the standard bar. Keeping in mind that the standard anti roll rate on the front of an R32GTR is not too bad, however the rear anti roll rate is grossly underdone, hence why the increases there are more than double the front.
Obviously with an adjustable (bladed) bar of larger than standard diameter the extra material has to go somewhere, in one or more of the 4 directions (up/down /and/or forward/backward). We choose the direction least likely to cause interference. You are the first person I know of to have an issues on an R32GTR with driveshaft contact. We make over 300 R32 front swaybars a year, so it is obvioulsy a pretty rare occurance. Looking at the possible issues, my guesses would be more front end geometry (caster/camber) than the average and/or the ride height is perhaps lower.
Whatever modifications the swaybar needs we can do, just get Ralph (Trutrack) to give me a call and we will work through the solution.
Cheers
Gary
I had this information all written down but unfortunately it is not to hand. I will try & dig it up.
From memory the Cusco sway bar I bought for the rear of my R32 R was 20% stiffer than the equivalent Whiteline bar. For the front the disparity was greater.
When you look at the lever arm component the Cusco pickup point is matched to the inner of the two Whiteline drilled holes (Or the middle one if you have the extra drill hole). The Cusco bar is also quite a bit lighter. The Cusco pickup point (for the lever arm) is the same as the stock item. Also the bar geometry ie bends etc are very similar.
I didn't buy a front Cusco bar because my Whiteline on is still set on soft, whereas the rear was on hard (Although I could have drilled more holes).
If you have inner & outer diameters you can compare bar stiffnesses by raising the diameter to the 4th power.
So eg a 22mm bar compared to a 20.5.
20 raised to the 4th power divided by 20.5 raised tot he fourth power = 234256/176610 = 130%
ie 30% stiffer.
If the bar is hollow you subtract the inner diameter to the fourth before you do the division.
Interestingly (Or not :thumbsup:) the Cusco items have a welded on end connection (The bars are hollow). So I am unsure as to what they are made from. I haven't had sufficient enthusiasm to remove the bar & bring it to work to find out. The % carbon in the steel is the tell tale - higher carbon in this application would indicate spring steel.
Edited by djr81
Yes, my group buy/whiteline front bar touched the driveshafts (just, it fit but rubbed). After a tickle with the grinder all was good.
  • 1 month later...
Ok, have semi sorted some new bars...but regarding the ARC ones. From looking at the diameters i suspect they are solid, not hollow? Does anyone know what the std GTST and GTR swaybar diameters? I am thinking that the non adjustable bars are hollow, just looking at the fabrication, and the adjustable bars are solid? Does anyone know for sure....have any old Hyper mags detailing them ?
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
