One of my headlight globes blew recently and i was wondering how do i take the headlight cover off to change the globe, and it says xenon in the light, so do i need special globes or what and where can i get them?
if anyone can help it'd be much appreciated, thanks
https://www.sau.com.au/forums/topic/227809-r34-headlight-removal/
ill find you a guide i found out how to do it myself its pretty easy you mainly just unbolt the 4 bolts holding it down which are easy to see, lift it up a bit and remove it from the back. 1 sec i have a guide let me find it for you
there are these big skrew like caps on the back of each headlight, cant miss them, just unscrew it and you have access to the screw in globe holder piece, pull it out and pull out the globe, quite simple really, wont take you long
i couldnt get mine out unless i took off my front bar.
when i installed my xenons, i had to bend the area around the headlight just to pop it out a little bit.
very dangerous as the plastic may crack.
you need H1 globes.
one of my headlights blew the day i got my 34, as said it takes H1's,
it was a simple matter of un screwing and screwing in the new ones, ( i have the factory bar, so i didnt need to move or remove anything) be sure not to touch the globe on the new one, or avoid it as much as possible as your fingers will leave moisture and the likes on the globe which can cause it to blow out sooner rather than later :)
  • 3 weeks later...
do i need special globes or standard ones fine? It's just my headlight is out, not the highbeam or parker
Hi
U will need the proper H1 globes. and there not cheap. if u cant find one i have one here.
Adam
I just did this a couple days ago on my R34. You don't need to remove the headlight housing itself, just remove the globe by unscrewing the big wheel-shaped plastic bit directly behind the headlight.
However this is harder than it sounds due to one small little screw that can make your life hell (well it made mine for about half an hour anyway). There is a screw in place at the bottom of this plastic wheel that stops you from spinning it. You need to undo the screw first. The screw head (on my car anyway) is not your standard screw, it's not even a phillips head shape. Its some weird star shape and I have no screwdrivers that can undo it. So in the end I just ended up using my screwdriver to jam it open (not ideal, but I was frustrated).
When you replace the globe, any H1 globe will do. Make sure you get 55W and not 100W. I bought a Phillips one for around $10.
Edited by BLACK34
  • 4 weeks later...
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
