Hey guys,
I dont know if this post has been done before but basically I want to know who tuned your car.
Please include:
MODS
Power Figure
Price
ECU (PFC, Microtech ect)
Service - Was it good or bad?
Please also PM if you have any bad info on tunners or people I shouldn't use.
I want to book my car in to get tuned. Its an RB25DET with Power fc, and bolt on mods.
Kind regards
Sam Murray
P.S if this a repost some on can slap me and point me to the original post that would be awsome! I had a look but couldn't find it for Tas.
Edited by sam.murray
https://www.sau.com.au/forums/topic/228041-who-tuned-your-car/
Dr Drift, R31 RB25det
MODS; TD06, injectors, exhaust, CAI, fuel pump.
Power Figure; 240 rwkw @ 13 psi, 255 rwkw @ 15.5 psi, 265 rwkw @ 19 psi
Price; $650.00
ECU; Factory Nissan R32 GTS-T
Service; Fantastic!!
Pro Automotive, R34 GT-T
MODS; FMIC, injectors, exhaust, CAI, fuel pump.
Power Figure; 210 rwkw @ 13 psi
Price; $300.00
ECU; Power FC
Service; Excellent!
Boost Automotive, R32 GT-R
MODS: HKS GT2530's, intercooler, exhaust.
Power Figure: 311rwkw @ 1.1bar
Price: $850 from mem (that included Plugs, Oil and wheel bearings)
ECU: Power FC
Service: Excellent
Boost Automotive, R33 GT-R N1
MODS: exhaust.
Power Figure: 323rwkw @ 1.3bar
Price: can't remember
ECU: Power FC
Service: Excellent
Andrew at Pro Automotive is very good and cannot recommend enough. He will provide a safe tune that you do not need to worry about.
Pro Automotive, R32 GT-R VS-II (2005)
MODS: Exhaust, N1 Turbos, Nismo fuel reg, K&N panel filter, 95RON PULP
Power Figure: 255rwkw @ 16psi (Dyno Logic)
ECU: Mines VX-Rom
Service: Excellent
Car Performance: Consistant fifth position on most stages at Rallye Burnie that year
Pro Automotive, R32 GTS-t (2004)
MODS: Exhaust, FMIC, 98RON PULP
Power Figure: 177rwkw @ 17psi (Dyno Logic)
ECU: Unichip
Service: Excellent
Car performance: low 62s at Symmons
Howell Automotive, S14 (2003)
MODS: Exhaust, HKS pod filter, fuel reg, 95RON PULP
Power Figure: 180rwkw @ 17psi (Dyno Dynamics), but struggled to show more than 150 on Pro Automotive Dyno Logic dyno
ECU: Unichip
Service: Excellent
Car performance: low 63s at Basky
R32 GTS-t - RB20
MODS: TD-06 20g l2 kit with 10cm rear, 3" dump, FMIC, stock cat back/injectors/afm, 95RON
Power Figure: 205rwk @ 14psi
Price: $650
ECU: remapped Central 20
Service: Couldn't complain at the time
Im currently looking at tuning option for old girl again with the new set up and after talking with Kuc he was not only extremely helpful but also came straight out and said that i should have a look around at other tuners as he didn't feel he could get the best out of my set up.
Even after that he has still taken the time to answer questions that i've had so its a big :) for me to Pro Automotive
I had my 1600 (FJ20) tuned by Kuc and the stanza (Z18) was tuned by Griffo using Kuc's dyno :)
Boost Automotive R33 RB25det
MODS, 3in turbo back exhaust, front mount, fuel reg, fuel pump, Greddy plenum, pod,
Power Figure 214km @ 10psi
Price bit over $500
ECU Power FC
Service - as posted in a thread last year, was not happy with the service at all, quoted $300 to adjust the map as it already had been tuned. they went ahead and put iridium plugs in it and removed some of the silicon hoses and put heather hose there instead.
have sent several cars down to Kutsie at pro automotive and am very happy withthe results. he's very good with comunication and will talk to u about what you want to use the car for etc.
Pro Automotive;
MODS; Fmic, Hks pro s 2835 turbo, injectors, cams, plenum, fuel pump
Power Figure; 228 rwkw @ 15 psi,
Price; carn't remember
ECU; power fc
Service; ok. I would never bag him out, there is plenty of people out there who have got great results.I just didn't get the result I wanted.
Dr Drift
Power Figure; 260 rwkw @ 15 psi
Price; $150.00
ECU; Power FC
Service; Sam only had mine on the dyno for an hour, I didn't want to go above 260rwkw as i don't want to risk the standard bottom end. very happy with his service.
Edited by woolls
Boost Automotive;
MODS; Fmic, VG30turbo, injectors, fuel pump, A/MDump pipe, Elec boost cont, Pwr Fc
Power Figure; 248 rwkw @ 15 psi,
Price; think it was about $430
ECU; power fc
Service; ummm, not bagging, but lacks costomer service skills at times.
Boost Automotive;
MODS; Fmic, twin T3/T4 turbos, 1000cc injectors, cams, plenum
Power Figure; 399 rwkw @ 17 psi,
Price; Think it was about $400
ECU; Haltech E11v2
Service; great.
This was my old RB25 and will take the new setup to him also. That is all the same goodies on a 25/30
Well theres only a few choices in tassy realy. and if you read every thing on the net they all have strong positives and negatives.
i recently took my car to boost
MODS: FMIC, gtr injectors, r34 turbo, good dump pipe and 3" straight through exhaust. runing on and rb25de
power: 194rwkw on 10psi but detuned for a slipping clutch
Price: $420 including iridiums
ECU: power FC
Service: i was happy with the service but and there is always a but it cost nearly doubble what i was advised (not quoted) would have been close bar the iridums
i was very happy with the feed back about my motor and alike. ive been told this isnt a strong point with boost but i was happy.
i am unsure if i will try some where elce next time.
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
