Ok good stuff guys! I'm considering doing the "Tasmanian Tarmac Challenge" in October if I can get the new car sorted out, Mt Buller if funds/time allow, and really aiming towards Targa Tasmania again next year in April. Rally Tasmania in February is always a great warmup for Targa Tasmania, but I just can't afford to do them all, time or money wise :ermm:
Makes me think actually, I better get on a diet so the poor lil' RB20 can drag me up the hills. Nah, easier to get co-driver whore Timmay to drop down to a sparrow-like 55kg I reckon. :D
Wow thanks for setting me a target now!
Greetings Snowman + friends.
I'm hoping to do Targa rookie next year also, so that probably means no Buller/Lake Mountain this year :D
I did scrutineering school last weekend. If you guys are wanting official help at your events, please PM me...
Cheers,
Scott.
If anyone has questions about tarmac rally eligibility or safety etc I'm the Technical Manager for Targa Tasmania so feel free to ask as its really not that hard to get a car together.
I used to race and rally various Nissan's including 200SX, R32 GTS-t and R32 GT-R... I navigate in an Integra Type R and currently building an RX7 SP so not just another useless administrator... well hopefully not that useless anyway!
What’s the ruling on dry carbon panels and 3mm lexan/plexi glass windows on the doors, rear quarters and rear window?
Depends on the car really...
No good for GTR on either point though. On GTSt the lexan works, but the windows that open need to remain functional and usually scratches like hell.
Any bolt-on panel could be swapped on GTSt for CF, but doors need to remain metal.
CF on the GTR only works if its a Nissan option (eg Nismo or Autech) such as CF bonnet, undertray, wind blade.
Thanks Stuart.
I don't believe so. I am on the hunt for some dry carbon bits though. ie, gtr style bonnet, bootlid/gtr wing/gtr nismo lip spoiler. Also hunting for some gts M-spec side skirts if anyone knows of any of these things?
Now, if I can just get an RB30 hybrid ok'd I reckon I'm in with a shot.................
Dane - The GTR is classed as a faster car under the parity rules so limited in permitted mods.
GTR guards on a GTSt would be cool, but althought the material can be changed (to fibreglass or CF) basic body work must retain the same external shape as standard with the exception of some aero like GTR wings and bumpers etc.
Guard rolling, just the inner lip not flaring? For example, are they going to raise question over a very minor appearance chance’s as one of the cars does look different next to another Gtst..
Edited by Nismo_Boy
    • I don't think the shuffle can damage the turbos. It only happens at low shaft speeds and loads. It's just annoying (to some people - others are tickled by the effect) and it quite possibly reduces spool performance a little bit.
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
