looks good andrew....but damn low. you need to be really careful with clearance it can't be anywhere near track level unless you are happy to do a sump :D
good luck with getting hold of tarmac's money guys. I would prefer to see the cover price I pay going to someone on here :)
Hey Dunc - the car will be raised next week. Even if for no other reason that so I can get a damn jack under it! Those side skirt extensions mean I only have 120mm clearance now. But I know from just some decent cruises that the car bottoms out on the exhaust so it was always going to be raised a bit anyways.
you know that problem (can't get a jack under it) really used to shit me....until someone pointed out the front tow points. You can get to them with any decent lowish jack no matter how low the car is. And if you have a good cage it should lift both sides of the car together.
Nice one Kel! When do you head over? And are you doing delivery vehicle duties again? We're on the Wed night boat.
Cheers :(
Not sure of travel arrangements and duties just yet - the Donut King guys are just back from racing the 24-hour in Dubai.
Good job boys. Thats a cracker of a classic car so you should have some fun. I'll have some beers on ice at the finishing line waiting for you! :P
PS - we expect at least 1 stage time faster in the R32 than you did in the R34 :P
Should be a cracker! Not sure where we could make up time, Georgetown perhaps? (sniggle :P )
Anyone care to explain how Outright Classic and Late Classic works? I take it one is a handcap or something?
    • Yeah well per the video it took 15s for the stock unit to start up....even if I give it a few seconds discount for starting that is at least 12 sec before you get a reverse camera if you are trying to leave a park.  The android unit is way faster, but 2016 for the stock unit is a long time ago in consumer electronics
    • Yea that’s why I said ima test them with multimeter and see the reads.
    • Only at idle. Isn’t a problem when rev it seems.
    • @Haggerty This seems silly to ask, but are you confident in your ability to tune the Haltech?
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
