Jones had a comfortable margin in the end, Quinn was disqualified for an "exhaust irregularity" :D
good to hear, I beleive he has previously been warned about one or more "irregularities" in prior raliies as well. In my book if its not right you should be excluded, especially if you finish on the podium.
Well done Steve!
Klark Quinn was also excluded for running a 2.2L engine in his EVO.
It will be interesting to see the fall-out from all of that.
The stupid thing about TQ's car is that other than weight there is no real benifit been found for running the full exhaust systems in these R35's. So there is no real reason for him to be doing it.
A 2.2L in an EVO is a different matter however! I think it would be good to see them crack down on these strokers though as they seem pretty rife through-out the sport.
Hooray, well done to Steve for another win, and I'm stoked to see someone caught with a cheat spec Evo, might fright a few dozen other blokes into complying with the regs now! lol
I wonder what the exhaust thing was with Puppa Quinn, does anyone know for certain?
did anyone notice that quinn had a spec-v sticker on his car for Targa Tas? and have you seen some of the cool things Garage Saurus are finding on the spec-v that was never publisized (bigger turbos, bigger throttle bodies, and who knows what else)
Interesting about Quinn Jr, puts a bit of the question mark over other LWR cars.
Benny, If you entered it as a Spec V, who would have the knowledge base to argue about any of it's specs???? lol
The car has to be homologated in Australia before you can run it. Since nobody has a Spec-V here, you can't run a stock GT-R as a spec-V.
Good to see Steve win even when up against a modified GT-R.
Pretty pathetic that Tony Quinn didn't even get out of his car after the last stage to congratulate Steve, when everyone else (including his navigator) did.
I'm pretty sure only Nissan jp know all the goodies on the specv ATM. But as Targa West is a CAMS event the specv trick wouldn't work.
Hmm questionable in general? Yes
Questionable on LWR's part? No
Think back to the last LWR EVO that won Targa/RT etc That was pulled down in protest and found to be std capacity.
I think someone else has had their fingers in the pie there
He was most likely contemplating ending his life " i cheated and still lost , i got nothing "
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
