Is all very interesting :)
Roy, nice choice mate. With the freedoms in Classic you could turn a DR into a good thing :)
You'll get good money for it if you do well in it. Only if the car is reknown for pace though. IMO
This is Brisby we are talking about here.
If he builds it (1.2% chance of him actually doing it rather than just talking about it!) it will look good, sound great but due to some whack theory he devises he will actually make it go quite slowly.
But it should end up with nice brakes if nothing else.
Feeling the love Bris??
You build it and I will drive it.... you seemed happy enough to let me have a crack in the RB20 of awesomeness at Benalia for some nuts....
Edited by Darkside
Whole early, early modern and late, early modern split is bogus, when post 86 was modern, life was so much easier! Without any knowledge of whys and wherefores, contention that the addition of late cosmetics, on an essentially unchanged platform, put you 6 or 7 minutes up the road....you gotta say, take the hand off the pud, gurus.
Yeah mate spotted that, but it's a fair way over the odds.
And Benny, no thanks. lol
buy my emo 6 RS. has the CR box (which is awesome for circuit/tarmac etc), has upgraded LSDs front, rear and centre. no gAYC or ACD, strong 200kw, ohlins suspension, TE37s etc. nice and straight and full registered. I'm getting keen to sell too so will move off my high horse!
I took it out to wakefield the other day and even on street tyres (dunlop Z1*) I managed a 1:12 which is bloody hauling considering I'm pretty shit behind the wheel. no ABS though I think (not that I've had any bad lock-ups, would be nice for tarmac though).
they are farking quick and with all the LSds the thing is still a bit hairy and fun to drive. it does have way more grip that it deserves though!
I'm not quite sure who/what you're taking aim at? Care to elaborate? I think you're referring to Series 6 through 8 RX7's?
Let the record state, I for one couldn' give a rats arse about them. Come one, come all I reckon :)
Richard your being an enabler! Can you go and sell some crack to some teens instead?
you been following me again? lol, it's not like i'm adding another emo to the world. just passing one on! wooster is already practically a woman in pants so the emo will suit him to a tee.
well in my RS is mech clutch plate for the center LSD, just like the front and rear. not sure what the stock VI has. probably open diff?
all I can say is if I can pilot that car to a 1:12 at wakefield (bear in mind street tyres, 200kw and small brakes), then it's a fking weapon of a car. cause it sure as hell isn't the driver... I can't drive a greasy stick up a dogs arse.
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
