Yeah "both" cars = race car and the road car.
Bit of a bargain too I reckon, I hear a figure of $320k for the pair. Keep in mind the road car full Aussie delivery and is practically new.
I don't know if I'm supposed to tell what the new car is? lol
You know they have an R35 though huh.....
Edited by Marlin
Is it possible to ever tire of listening to YT's Lambo?
http://www.youtube.com/user/bradsegda1#p/a/u/0/Q7z8f-j72sg
Must own one of those before I die.
New engine... gee i wonder why!
Me too mate! :wub:
mate, if I wasn't engaged we could get hitched. just think. forget double the wardrobe! double the garage!!! plus we are both tall bastards so all our cars would have nice low seats for headroom and legroom. E30M3, few GTRs, your radical. match made in heaven. you pitcher or catcher? lol.
Kim Ledger was trying to get that done but I believe he was failing in his attempt.
mmmm I am confused, Mazda RX8 SP you cant buy but is running, R35 RC you can buy but you cant run it, I dont know how does it work ?
I believe because basically the SP spec brings the Rx8 up from M2 category to M1 category so it can compete with the factory spec M1 performance cars.
The R35 is M1 category from stock, so to allow modding it to super duper spec would be an unfair advantage.
Despite bring M1, Lambos were allowed to be modded to Super Trafeo spec as it was deemed necessary for them to remain competitive mainly due to requiring a decent gearbox.
However, the Lambos have now been deemed to far from real to be allowed to continue, and from now on are required to return to much closer to a road car..... no more sequential box etc.
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
    • Hi.. Just another problem. So maybe you can help. I(my mechanic) done swap from my RB20DE NEO to RB25DET NEO. Everything is OK but we have a boost cut. Coils/Plugs are ok...AFM is ok. ECU is ok. I have Walbro 255 but it "changed" sound few months ago(you can hear it ouside) you did not hear that when it was new(maybe faulty?) Sooo...what now? What can cause this boost cut? It is even when you standing still...
