Email sent Greg ;)
Mel texted me asking if I was doing it, and she said she had plans to.... maybe you should talk to her :P
The dirt looks like a lot of fun (to drive), but it's the pulling apart and fixing the grubby things I don't rate :)
^^^^ Thats the only lack of appeal to me of the dirt. I really like the idea of sliding around on a budget, but the ongoing servicing, repairs and maintenance, even if you run a clean rally and dont touch anything could get on my nerves abit. That said, i havent done it so am only speculating.
tarmac, as long as you dont crash, quick wash, fresh fluids etc, and away you go..
Hmmmm.. group C RX 7 turbo..... Anyone who will pay sensible money (see what I have done there Woo :) ) want to buy a Targa Prepped TME? Is CAMS logbooked so will be good to go for next year.
Does this also mean that the other CAMS rallies will fall in line regs wise with the Octogon rules (Targa West, Rally Tas, Mt Stuart etc)??
Be good if there was just one set of rules thats for sure.
+1, good call
I would say its only a matter of time. The CAMS regs are one reason I cant be arsed respeccing my car and running at Targa West.... the shite roads and repeated stages is probably the other. :)
CAMS have already relaxed their rules on exhausts. I expect injectors and fuel pumps etc will come soon to embrace the E85 phenomena. Then its just the silly ones like adjustable strut tops etc to get rid of and you are just about there.
All this talk of new projects has tempted me to put the EMO on the market. I am asking crack pipe money for it on MY105,(39k) but if anyone is seriously intersted let me know. :)
To your question Ben, I would have thought CAMS cage and logbooked, but I cant be sure. That said, from what I remember, if you have a CAMS certified cage, the next step to logbook the car isnt much more than filling out a form and getting it inspected by a CAMS srutineer.
Should be a piece of piss Ben as your cage is a very similar YT spec to the IX just need a scrutineer? to sign off on it.
Best bet is to give Herbie a call at the CAMS state office and he will point you in the right direction.
Getting a rego inspection was harder than getting the cage log booked (too many anal RWC stations), in the end Transport just pushed it through with out one!
Apparently there are proposed changes to ROPS spec in the pipeline now that are due to be put in place January 2012. (Think there was a CAMS bulletin recently) You will need to get your car logbooked by then if the cage is built to current specs or if you miss the date possibly find yourself having to mod the cage to make it comply.
There are no major changes for new cages from memory, mainly that you need 2 cross bars in the main hoop or rear legs, and changes so that FIA cages will be cams compliant.
All Chromoly cages will ned to be inspected/tested by a CAMS offical before log booking
CAMS has a whole new section up on the site about the changes.
Finally seem to have the ability to reply - woohoo!  Had all sorts of trouble with my iPad and this forum, but found a cool app that seems to work... Sort of...
So I wanted to stop this nefarious rumour The Woo is trying to spread .... It seems that merely enquiring after another's interest in an event constitutes entry (if only this were true).  Boy I had a lot of explaining to do to my husband (pool heaters)
The closest i will get to being at Classic Adelaide (or any other event in the foreseeable future)  is if Kel takes up my offer to be her groupie .... And even that's not looking so good right now - I hear I need to slay her other groupies to be considered at all, as she has set up a master chef / DWTS elimination style process
(now counter-rumoured, my work here is done)
Mel
Edited by datgirl
    • Have a vb in honour of the car comming back
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
