We flew down to Tas on Friday and spent the weekend driving the course in a Hyundai i30, 2000km in 2.5 days was a bit of a stretch but we managed to drive every stage. Once.
Excited & nervous about the event, so many nice roads to drive on and so many places to come unstuck. Think i prefer the north-west & west coast roads to the east, just depending on whether it's wet or not.
Has anyone driven Riana lately? The bridge towards the end is a little, err, not finished?
yep we are on smoothline too, only on the medalian. How much more info is in the trophy notes? I'm using 1-10 instead of 1-6, so i'm hoping it won't take too long to get my head around the different numbers.
after we ran the car on the weekend, i'm feeling a lot better as far as prep time goes. But dad blew the turbo on his Subie, and one of the turbo's on the GTR at the V8's last weekend.
Edited by sav man
Yes Holwell certainly looks interesting! There entry onto that straight is very fast, so no doubt all cars will be pinned in top gear for some time before hitting that big crest!!
I take it you had a run at Baskerville on Saturday Ben? I passed you at Kempton, I was heading north for recce. Hope to finally have the car back and put in some time at Basky myself over the Easter break.
Mid detail for a corner or crest etc which is a little bit longer than normal but not considered long, few other things I can't remember off the top of my head. Ill try to look tonight to remember!
I hear Holwell is going to be scary, the big straight which used to have 2 chicanes is now unrestricted. Should be some massive air at the end.
Yeah it is! Our notes read something like 1.1km to crest straight caution air 300 then crest straight air 200.
~ 240km/h + crest = ?
Massively airborne scares me. Can go soooo wrong....but can offer up such a great "poolroom" shot or avatar eh Ben?? :)always hard to determine at recci pace how fast will be a cool little air or one that fills the pants of your driving suit.
Captain sent me a text last week saying he thinks a number of tears will be shed on the 2nd last stage.
Not sure what it is called but he reckons it's full of surprises.
^^ That would be Woodsdale, from memory it was quite narrow, rough and is off camber on either side going into a ditch for most of the way. Reminded me of Pelverata but narrower in some places. Wouldn't take much to slip off the center of the road if it was wet.
Word on the street is that Ricards is in for glenney in the chook cooker
Yeah heard this last night. Apparently poor Squeak is gutted, we will have to share the sorrow of service crewing together..
On an entirely different note, what is the general consensus on a DR30 Skyline for a Tarmac weapon?
Been offererd a "fresh from Japan" 1983 iron mask model today for $10k. Perfect condition, no rust and a fresh engine. I know very little about these, but they would seem to fall into a pretty competitive section of late classic?
I am well over finishing (read starting) my RX3 project, and one of these looks way less work. Might even give those punters building turbo RX7's a run? :)
All advice gladly accepted..
paul
Has been discussed earlier in this thread Paul, and I think the general consensus was they would be a good thing.. probably only thing holding them back is availability of FJ20 engine parts. I rate them anyway!
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
