We flew down to Tas on Friday and spent the weekend driving the course in a Hyundai i30, 2000km in 2.5 days was a bit of a stretch but we managed to drive every stage. Once.
Excited & nervous about the event, so many nice roads to drive on and so many places to come unstuck. Think i prefer the north-west & west coast roads to the east, just depending on whether it's wet or not.
Has anyone driven Riana lately? The bridge towards the end is a little, err, not finished?
yep we are on smoothline too, only on the medalian. How much more info is in the trophy notes? I'm using 1-10 instead of 1-6, so i'm hoping it won't take too long to get my head around the different numbers.
after we ran the car on the weekend, i'm feeling a lot better as far as prep time goes. But dad blew the turbo on his Subie, and one of the turbo's on the GTR at the V8's last weekend.
Edited by sav man
Yes Holwell certainly looks interesting! There entry onto that straight is very fast, so no doubt all cars will be pinned in top gear for some time before hitting that big crest!!
I take it you had a run at Baskerville on Saturday Ben? I passed you at Kempton, I was heading north for recce. Hope to finally have the car back and put in some time at Basky myself over the Easter break.
Mid detail for a corner or crest etc which is a little bit longer than normal but not considered long, few other things I can't remember off the top of my head. Ill try to look tonight to remember!
I hear Holwell is going to be scary, the big straight which used to have 2 chicanes is now unrestricted. Should be some massive air at the end.
Yeah it is! Our notes read something like 1.1km to crest straight caution air 300 then crest straight air 200.
~ 240km/h + crest = ?
Massively airborne scares me. Can go soooo wrong....but can offer up such a great "poolroom" shot or avatar eh Ben?? :)always hard to determine at recci pace how fast will be a cool little air or one that fills the pants of your driving suit.
Captain sent me a text last week saying he thinks a number of tears will be shed on the 2nd last stage.
Not sure what it is called but he reckons it's full of surprises.
^^ That would be Woodsdale, from memory it was quite narrow, rough and is off camber on either side going into a ditch for most of the way. Reminded me of Pelverata but narrower in some places. Wouldn't take much to slip off the center of the road if it was wet.
Word on the street is that Ricards is in for glenney in the chook cooker
Yeah heard this last night. Apparently poor Squeak is gutted, we will have to share the sorrow of service crewing together..
On an entirely different note, what is the general consensus on a DR30 Skyline for a Tarmac weapon?
Been offererd a "fresh from Japan" 1983 iron mask model today for $10k. Perfect condition, no rust and a fresh engine. I know very little about these, but they would seem to fall into a pretty competitive section of late classic?
I am well over finishing (read starting) my RX3 project, and one of these looks way less work. Might even give those punters building turbo RX7's a run? :)
All advice gladly accepted..
paul
Has been discussed earlier in this thread Paul, and I think the general consensus was they would be a good thing.. probably only thing holding them back is availability of FJ20 engine parts. I rate them anyway!
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
