What are the problems with the DR30 rear end? Is it the camber change like a 1600?
Not sure what to do with this car till we get it and see what spec it is? It ran LMS in 2001 so that would be very close to SS now. Eventual plans are for full MS build incl S13 susp and steering, RB cr g/box, serious llightening etc. Might run in an event or two as is and see where to go from there.
I saw there was an Escort in the ocean on that 2001 Targa Tape, is that the same spot as the 2 cars at Wrest Point?
Congrats on the new addition Paul! Sneaky fella aren't you.... not a whisper of it :)
Further enquiries re Rexy's dak dak brakes. Good authoretehhh tells me CAMS disabled and sealed the system prior to the event. Well there ya go. The old fox can steer a bit :)
Other news says there will be further simple steps taken to completely eradicate the use of ABS where it's not allowed.
The DR30 has a similar design to the 1600 and Bluebird as far as i know, heaps of dynamic camber and bump steer.
I enquired to Benson about putting a R32-4 rear end in. And it needs to still be a semi trailing rear end, as it needs to be the same 'type' (live axle, semi trailing, multilink). With the rules you can fix it, but it will need a bit of thought and designing. E30 bimmers, and the 911 RS's seem to be fine with semi trailing.
No sneakiness to be had Benny. I actually looked at a different DR30 drift spec car in Hobart while we were there, and when asking various peoples' opinions on this car on the way back to Brissy it was mentioned that another might be for sale. Just one of those "right time right place" things I guess (hope)? Time will tell if it is the right move or not?
In regard to the rear end, I know the gravel rally guys here have a mod to reduce the camber change on their 1600 rally cars, but for the moment I will see how it goes as is. There seem to be a few 240z's and Porsche 944's doing ok with a standard trailing arm setup this year? I am no expert though, this is my first venture into the earlier Nissan days! All advice greatly accepted.
Still, I look forward to seeing how you end up with it Paul :)
How to fix camber changes..... Is it really all about the speed though? If ya wanna impress your mates, just upload in-car to YewToobe with a sneaky 15% increase in play speed.
Everyone will think you're a weapon then, and your nav will sound like he's just really excited!
It really is more about the event than winning a class I reckon (spoken by a bloke who's not won much lol)
Dude, you've got the cred. Just because your car breaks, or you don't win is irrelevant (although it would be nice). You've been there - which is something lots of us appreciate and would aspire to. You're not a keyboard warrior making up crap.
:worship:
:worship:
You doing the 'two profile' thing again Benny? :spank:
Haha nah, I'm building up a track car. Just envious of you guys that do the serious stuff. Hopefully I can pilot a jet at speed....
    • I thought I'd do a write up on an auto transmission fluid change for a the nissan 7 speed Automatic. At some stage the genius engineers decided that the fluid in the trans was "for the life of the transmission", (which seems kind of self supporting to me) and removed the dip stick and fill tube (funnily enough there is still a casting for it). Anyway, for this job you do need 2 specialist tools in addition to regular hand tools, jack and good chassis stands. You need a way to pump fluid up to the transmission; I got one of these but there are plenty of other options: https://www.ebay.com.au/itm/364584087070 Don't trust the generic listing though, it does not come with the required adapter for the Nissan 7 Speed. You need one of these, can't do the job without it: https://navarapart.com.au/product/genuine-nissan-patrol-y62-d23-np300-navara-re7-dipstick-fill-connector1 You need a heap of compatible transmission oil. Could be Nissan, could be anything else rated for Nissan Matic S. You need at least 10 litres, I had 15 to give it a better flush... Also, you need some biiig oil catch trays, at least one of these, or bigger if possible (volume was fine, size was very marginal): https://autobarn.com.au/ab/Autobarn-Category/Tools-%26-Garage/Specialty-Tools/Oil-Service/Garage-Tough-Oil-Drain-Pan-Black-16L---GT1068/p/TO03191 Finally, a measuring jug is very useful if your pump does not have volumes marked on it, I got a 6l one: https://www.repco.com.au/oils-fluids/fluid-accessories/measuring-jugs/penrite-measuring-jug-6l-pmj006/p/A5322648 Oh, and gloves.....this stuff is horrible (not as bad as diff oil, but getting there) ....First, jack up your car.....
    • So I mentioned the apprentice, @LachyK helped take the bonnet off. We just undid the nuts on the hinges and unclipped the gas struts, then pulled the bonnet back a little as the front was catching on the front bar.  I had a good look at everything today and have removed the rams, repaired/reset the hinges and bolted it back together like it never happened. I'll do a separate write up on the repair, and I also removed the poppers from the Fuga today too to save grief down the road.....as said above it is at least $5k to repair retail. I'm also happier about my ability to prepare a race car, and less happy about Nis-nault's engineering (I can hear @GTSBoy sAfrican Americaning) because the top hose of the radiator didn't slip off.......it snapped clean off. By practice I put the hose clamp hard up against the flare on a neck to make it least likely to ever move (thanks @Neil!). I guess that puts a little more pressure on the end of the pipe as it is further away from the rad, but still, that is pretty shit. I've put it back on for now as there was a fair bit of neck still there, but obviously there is no lip on the neck any more so I don't think I'll track it again until I have a new rad. Speaking of which....more research required. It looks like Koyo makes a standard size radiator in ally which I'll grab in the meantime, but I really want something thicker so might have to go custom in the medium term (ouch) Coolant still needs a refill and I have the pressure tester on it over night, but other than a wash down of the engine bay it seems alright. And @MBS206 noted something noisy on the front of the engine and I think I agree....time for a new accessory belt and tensioners I think.
    • our good friends at nismo make a diff for it, I have one (and a spare housing to put the centre in) on the way. https://www.nismo.co.jp/products/web_catalogue/lsd/mechanical_lsd_v37.html AMS also make a helical one, but I prefer mechanical for track use in 2wd (I do run a quaife in the front, but not rear of the R32)
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
