^^^^ That would be great Mark. After having just spoken to racing beat in the US about building a motor for me I am not so sure I want to sell all my organs plus any furure unborn children to have one of their engines. I am sure they are top notch, but circa 20-25k for a rotor engine build (complete long motor with turbo etc) is a bit beyond my budget.
But at the same time, happy to spend decent money to get something I hope will be reliable. Tassie is just too far to go for me to have a mechanical early on.
While RB did have a bit of a tech edge in the past with screw in ports, cooling mods to housings and so forth - even if they did use their alloy plates, ianettis they usually recommend, 2 piece eccentrics and so forth, that's well OTT.
consider going japanese? they know how to make a good rotor motor. had my FD RZ's motor built in japan at a shop called pre-stage. was bloody quick (in build time) and performed very well. Cost was reasonable too.
There's no secret sauce in any country - although some of the locals practicing the art here probably would have been more suited to wild west blacksmith occupations. Your ex-RZ went ker-blammo very shortly after the sale.
I am suffering the same thing..
i am really trying to get excited about building an early rotor to run in classic but am finding it hard to get really excited about it. Probabaly should have just kept the evo :(
One of the long time classic rotor guys did the switch this year, damaging the now 30k + Rx3 probably the turning point. There will be someone else doing the switch too next year.:whistling: With the price of rotor engine parts going through the roof, you can basically get 4 cylinder rods and forged pistons with change for two new rotor housings.
If you want to persist..... it's no Rx7 though.....
http://my105.com/lis...ls.aspx?id=3467
Hearing ya Ben. Advice I was given very early on was don't head to Targa with anything you can't afford or risk throwing in the bush.
Funny thing, guy I mentioned some pages ago with the GTR, ended up having to make lease payments on two cars after writing one of them off at TT.....when these were worth a bit of coin too.
^^^^ There are just so many ways to crash at Targa and sooo many variables. Even with the best intentions, some rain and a fluid spill or something else unexpected could easily have you off the road.... and then there is always the red mist to contend with if you get passed or are getting caught.... :)
bummer 2pee. didn't know that! :(
the RX4 on my105 looks pretty good value. especially with 2 engines and another in bits!
but yeah rotors can be a whole lot of pain. but when going well they are great.
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
