Alright sorry if this has been talked about before but I have done a search found some info but not what I’m after.
1st of all My car is not a skyline its a lancer
Anyway to the question what is Wrong with a gt3040? I have been advised it is a miss matched turbo how so and how does this effect Power/Lag and so on? As im trying to decided a turbo for my car and I was thinking a gt3040 .63AR (gt3082) would be best for what I want but after reading that it has put me off a bit.
I have also read that a GT3076R-15 .82AR Is rated at the Same power as a GT3040 but has less Lag does this mean also less power up top? And last on the list anyone using a GT3240?
The Engine mods on my car include
HKS 2.3L stroker (been advised by HKS it will REV to a max of 9500rpms with head mods) my RPM limit will be set at 9000rpms MAX but more at the 8500 mark
HKS kansai intake manifold
Cams? Unknown what ones yet looking at 270s maybe 280s depends on turbo choice
Plus a list of other mods but there the main big ones
And the car is being built for Tarmac rally’s / super lap / Track events
Sorry if it such a noob question it just I have read about 8 different forums in regards to these turbos and have not really gotten anywhere other then getting confused to what turbo I should buy
thanks in advanced
https://www.sau.com.au/forums/topic/228385-turbo-help/
Alright
look at it this way its a R33 GTST
whats the diff between the turbos i have listed is there anything wrong with the GT3040
i have read evom lancer registry and evooz the turbos techsport get are FP 20g wheel there good if you want around 260kw at all fours im not after what turbo is best for my car Just after info inregards to
GT3076R-15 .82AR << will this turbo still make boost at 8500rpms? anyone running this on there R33 GTST? or even R32GTST?
GT3040 What is this miss matched turbo i keep reading about what makes this a "bad" turbo
and GT3240 Is anyone running this at all?
there the choice in the turbos im going i just want to know if people can give me info in regards to the turbo not if it good for my car or not
hope that clears things up a bit?
And i may be going a twin scroll kit But been told they drop off up in the rev range so reading inregards to this as i may get a full race turbo kit setup
https://www.sau.com.au/forums/topic/228385-turbo-help/#findComment-4017999
R33 is 10 years old at best :)
Evo's use split pulse manifold, therefore keep with that and go a split pulse turbo.
Garrett dont make a split pulse housing that small i believe so you'll need something that does.
So again, something out of the US (where they are frantic about EVO's) or something from someone like Techsport (who've just recently released a new turbo, and are right into EVO motorsport here in Vic)
Twin scroll does not drop off. Its a turbo, its just running outta puff, a single scroll would too.
https://www.sau.com.au/forums/topic/228385-turbo-help/#findComment-4018089
evo 6 is a 9 years old, omg makes them sound crappy
i have been reading more lancer registry stuff then evoM, as evoM every one seems to be into drag evos and running gt35s or bigger where as LR seem to be track racers and rally people i dont care about i have read all forums i have spent hours on each one reading there turbo sections and searching info
all i wanted info on was the turbos them self as who cares what car it is on just want a bit more info on the 3 turbos i listed
And i wouldt go to techsport if they where the last mechanics on earth mods may want to edit that as i dont know if i can say that or not
https://www.sau.com.au/forums/topic/228385-turbo-help/#findComment-4018167
As far as modern turbo's go, a 30/40 is a bad combo, too small hot side compared to the compressor gives it poor throtle response, then choked the top end. What power are you looking at making? About to undertake doing up an evo V11 for a mate, and the stock turbo/s are good for 240awkw, above that and i would just be getting a big 16G or 20G
https://www.sau.com.au/forums/topic/228385-turbo-help/#findComment-4018315
OK one of my mates has an EVO 2 which in an earlier stage of its life was running a .82a/r GT3040 (GT3082R they're called these days) on a 2litre 4G63 which he ended up changing up to a .82a/r GT3582R. I never went in the car with the GT3082R but the GT3582R is surprisingly useable and he believes he should have just gone straight to that - definitely never looked back. He uses the car for track and hillclimb events and is always at the very pointy end of the field. The car feels quite NAish up to around 3000rpm but after that it starts piling on boost quite quickly and by 4500rpm it is fair honking along. It currently uses a 272/280 Kelford cam combination and makes good power up to ~8500rpm.
If you want to make good power up to those revs I'd be inclined to think a GT3582R is really what the doctor ordered for you too, almost everyone in NZ seem to go for those and again - the fastest time attack EVOs in NZ (and there are a LOT of hard tuned EVOs here) are running GT3582Rs, the fastest one I know of took out the two "Superlap" events we've had here and did that on an HKS 2.3litre :)
The GT3076R will make really good power, in my opinion go either a GT3076R or a GT3582R - a GT3082R is a pointless in between which isn't sure of what it wants to be.
https://www.sau.com.au/forums/topic/228385-turbo-help/#findComment-4019312
Thanks for the help from what im lead to believe the HKS GT3240 is just that a GT3582R thanks for the info guys and thanks for giving me the info on the GT3040 :) i have made the choice and a nice big turbo is on the shopping list and i guess i will run prob run the hks 272cams maybe push it up to 280s we will see
and in response to the big 16g evo 4 and above came out with a big 16g stock i believe well i have a big 16g on at the moment and it maxed out at 242 at all fours the next step is 20g and that maxes out at about 260 - 270 unless on race fuel and huge boost then you can look at 300kw
thanks for the help in regards to the Turbo’s them self as that is all i needed to know not really how well they would be on a evo but that was a bonus
https://www.sau.com.au/forums/topic/228385-turbo-help/#findComment-4019339
All the turbos above come in a kit for the evo
you can even get a BOLT on gt35kit that will use stock manifold
you can also get Twin scroll GT30 and GT35 kits for the evo from full race
the only downside to there kit well I think it is a downside is the whole Twin Wastegate setup
There is everything out for the evo in kit form You name the turbo good chance you can buy it in a kit as like i said USA = DRAG RACERS and euro RALLY CARS and JAPAN curcuit
GT3240 is used on the HKS Carbon fiber evo CT230 i think the cars name is (was all carbon running a 3076 now all red running a 3240)
i think i have narrowed the choice down to a 3240 and a 3582 the 3240 from HKS as a kit Or i will go the 3582 From fullrace or BR racing (br racing only use one wastegate)
https://www.sau.com.au/forums/topic/228385-turbo-help/#findComment-4019723
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
