Agreed...
I might have to give Paul a bell, come this time next year for a 26, or 26/30 build come this time next year if local options are no good.
Yeah if its a basic rebuild with nothing tricky (block grouting, port work, stroker etc) i can get them done in 4 weeks...6 tops. Ive seen shops taking 10 months over here and charging around $40 000...its highway robbery!!
every workshop would love a 40k engine job
however there are some people who arent after 700+hp
btw top racing wanted 13k for a rb25 rebuild (basic rebuild)
cp pistons
eagle rods
n1 oil pump
gasket kit
acl bearings
parts were around 5.5k and he said machine work was around 2.5k
that leaves labour to assemble engine/put in car at 5k?
^^^ $5k to assemble an engine and install in a car is cheap mate!
I am getting quoted over that to fit cams, cam cover baffle kit, cam cup stud kit, evc, pfc, water pump, timing belt etc, manifolds, dumps, turbos, fuel pump and injectors on a 33 GTR and change fluids.... oh that includes a tune of course.
Speak to people over east and they are talking $3k tops... Would be cheaper for me to put the car on a truck tranporter to Sydney and back but thhe risk of damage in transit aint worth it I reckon.
At this stage I am looking at going with x-speed who are pricey but I know the job will be done right the first time. UNLESS anyone here has other ideas??
my opinion is to go and check out ALL the big name workshops first. Dont ring or email but rather go down and talk to them. A few places thought i was bullshit or rather a timewaster. While others didnt even return my repeated phone calls. One particular place i waited 2 whole months for a quote but NEVER called me back!!! When i went to top racing i knew it was the right place. I suggest instead of listening to others ( even though nearly all would never of had a rebuild before) go and see yourself.
well I might take that on board, load the boot up with all my crap and go driving around to the various places to get a quote in the flesh to install and tune....
problem is I just found out my car which I thought was booked on the 29 July boat, for some reason did not make the boat and is STILL in japan.....auction was 28 June :D
Edited by R34kid
My prices start at $4K for 'basic' rebuild including machining and head service...plus parts. I also charge $1.5K to R & R the engine. $2500 for machining on a basic rebuild is excessive by almost $1000 if it doesn't include porting or fitting of new valve guides. Some of the bills ive seen from other workshops over here are unbelieveable. One totalled over $28,000 for a RB26 build and a gearbox overhaul. This bill was labour only and included no parts...the total bill exceeded $40,000. I could build the whole bloody car for a $28,000 labour build....some of these guys need locking up!
Edited by DiRTgarage
i dont think 5k is cheap to assemble and install an engine into a car
a couple of engine builders have quoted me 1k~ to assemble the engine
so thats 4k to put it in?
a normal workshop rate is $90 an hour
thats 44.4 hours
i highly doubt it would take 5 working days to fit an engine in
Just chase up a new engine then work on the price for fitting it separately, I know of a new Nur motor that just landed and it was the same price as places charge to rebuild one (freight and duty included).
The workshop fitting the engine rebuilds motors them self but even they see the viability in chasing up a new one in Japan especially on an RB26.
Just a tip mate. Most workshops get the blocks and heads sent away to engine builders. Why not go to the source and speak to them about assembling a motor if you provide the parts bought online you will save yourself some cash in the long run. In regards to getting the motor out find some friends or family to help or source someone cheap.
Also with workshops you'll find if you bring your own parts the labour might be higher in the case of you purchasing everything from them because they generally make some money on the parts around 30% ~.
Edited by monga
  • 5 years later...
hey guys whos is the go to guys these days for quality rb assembly like monga said, cheaper to take it directly to a engine machine shop, the question is who knows Rb26 engines inside and out in perth or ............. where in australia for that fact
Galvsport in Osborne park seem to have taken the cake lately as the RB specialists. Josh would have around minimum 10 RB26/RB28 builds on the go at the moment and very busy leading up to racewars. good bloke, will give you the time of day to have a chat about what you want and suggest from tbere
few pics of a customers RB28
post-100996-0-14824300-1394500300_thumb.jpgpost-100996-0-27834300-1394500307_thumb.jpgpost-100996-0-92407100-1394500318_thumb.jpgpost-100996-0-35515400-1394500322_thumb.jpgpost-100996-0-81765300-1394500323_thumb.jpgpost-100996-0-20790900-1394500344_thumb.jpgpost-100996-0-43616600-1394500355_thumb.jpgpost-100996-0-93651000-1394501392_thumb.jpgpost-100996-0-38803000-1394501417_thumb.jpgpost-100996-0-39514800-1394501420_thumb.jpg
Edited by janey babey
attachicon.gif3.jpgattachicon.gif5.jpgattachicon.gif7.jpgattachicon.gif11.JPGattachicon.gif14.JPGattachicon.gif11.JPGattachicon.gif9.jpgattachicon.gifIMG_0024.JPGattachicon.gifIMG_0023.JPGattachicon.gif15.jpg
cheers mate your another person that has recomended galvsport i sent them an email allready see where it goes from there happy days
Jane pls.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
