Been looking at both of these cars a bit an leaning towords the 33gtst series2. Most of the gt-t's i see are tiptronic but is it really any good. how would both the cars compare stock and how would a manual gt-t compare to the manual gts-t. just interested.
cheers.
https://www.sau.com.au/forums/topic/230788-33-gtst-vs-34-gt-t/
GDay Jackson,
Someone after me will surely supply you with some engine specs comparing the R33 GTsT with the R34 GTT,
but I'd certainly pick the R34 GTT for a couple of reasons (even though I like the R33 shape better - purely from a subjective angle)
i) being a later model car, you have more chance of getting one with less Kms and less wear
ii) street cred says that an R34 GTT (manual) has won the past two NZ Targas with its 4.1 diff (against GTRs, Porsches, STis, EVOs etc)
The plus for the R33 is that they're going pretty cheap and there's lots to pick from. Just pick carefully and try >3 on the day eh?
Cheers, T
GDay Jackson,
Cheers, T
What the hell are you talking about? :)
If you are talking about Joe McAndrew then his car is not a gtt, its a gtr!
Looks like a Black GTT to me! Just watched it again!
Never mind, let's get this thread back on the road and help our friend out eh?
Cheers, T
Cheers, T
Thats because it has a gtt front bumper :)
And yes, back on topic.
It is probly best that you go and test a r33 and a r34 for yourself to make a decision, each have their good and bad points such as
r33 is lighter and less powerfull
r34 is heavier but has more power
r34 is newer so should be in better condition
etc etc
And when it comes down to modifying both are pretty similar, espcially when it comes to engine modifications.
etc etc
True..
In terms of engine.. a GTT is in every way superior - More PSi from stock, ceramic turbo etc.
R33 GTST pushes 184 kW, 294 Nm
R43 GTT pushes 206 kW, 343 Nm
I am really not a fan of either cars..
But after driving both.. GTT hands down..
Save a little more for a manual GTT..
R33's these days are usually thrashed to the shithouse.. which means more km.. which means you need to replace things earlier.
34's have a higher cabin quality with more comfort..
I think the question you should be asking.. is;
33GTR vs. 34GTT.
Even then.. you could buy a 34 GTS4 and would be almost the same a 33GTR for a cheaper price..
Thats my 2cents
I've got an r34 gt-t which I bought after trading in my r33.
Noticable seating position difference, lower and sportier feel in the r34. Less rear legroom in the r34 being shorter overall, but difference is marginal.
Noticable increase in chassis rigidity in an r34, steering feels a lot lighter, turn in is sharper and much more stable powering out of corners, this makes it feel lighter and more nimble than an r33 but is a heavier car
coming from an r33 they're definitely a worthwhile upgrade, which you will notice when you drive and look at both.
No battery in the boot made it easier for me to install split speakers into the rear parcel shelf (battery put back in the engine bay for the r34 models)
no ugly external radio aerial on the 34
R33 GTR, probably more chance previous owner would've thrashed it (as opposed to a gtst)
insurance premium jumps moreso I've found (I looked into getting an r33 GTR before I chose the r34)
I'd imagine running costs would be a bit more expensive in the sense of insurance, replacement parts and repairs shuld anything go bang
all the best with your car hunting :P
Edited by Yo-Yo
hey man,
my 99 R34 GT-T manual is on its way from Japan atm
i got it for 17000 complied and landed here in adelaide.
5 spd manny with 50,000 on clock grade 4.5 outta 5 in auction.
lowered, exhaust, tint
no scratches or dents, perfect body.
DVD system with sat nav
white 2 dr.
I have a mate that has the same one so i tested it before i bought mine, and eveything about them is amazing. im very happy with it so i recomend the R34 GT-T by all means, r33 are nice, but i prefer a 34 by FAR! nicer looking cars in my opinion
But good luck with everyhting mate! im sure you'll find what your looking for.
Cheers, J
34 has a stiffer chassis too, even stiffer than an r33 gtr i think (happy for someone with more knowledge to either confirm or dispute this though, as I can't remember where i read it).
Plus, in my view more important than the differrence in KW is the better low-end torque of the NEO engine, 343nm@3200rpm vs. 295NM@4800RPM for the 33. This, and the better quality interior, is why most people say its a more refined ride than a 33.
if you want an R... like we all did.. buy it... you will ultimately wish you had.
33's are a cheap way into a well balanced car. Will take money to get the performance you will want.
chassis rigidity, 34 gtt's are 'better'... 33's feel sloppy as a wet fish without tensioning... SERIOUSLY.... being better isnt exceptionally hard...
33 vs 34 engines total output is not hte story... stock for stock a 34 will JUST beat a 33. the 34 will be more fuel efficient throughout the rev range making more average power throughout that same range.
p.s. they are all second hand cars...
as clarkson said and is quite accurate actually.... they have all been wound back somewhere around dubai..
33GTR vs. 34GTT.
Explain how this is possible?
I dont think a r34 gtt would come close. Ive driven a r34 gtt and my current 33 gtr.
The R is far more superior.
The gtt just looks "fresher"
  • 1 month later...
Ide take an R33 GTR over an r34 gtt anyday!
Thing is if you want a gtr, you wont be satisfied untill you have one...
Which is why i might be selling my series 2 r33 gts-t and upgrading to a 1996 R33 GTR V-SPEC series 2
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
