HELP!!!
Does anyone know anywhere to get coolant and oil lines to and from the turbos for a R32GTR.
They were bent beyond repair upon removal and Im just wondering if I have to go through nissan or if there's somewhere else cheaper...
I figure that whilst Ive got the engine out it should be fixed right... just to save me doing it again
Well...
A number of the traders on this forum are wreckers, would be a good place to start?
Failing that, the yellow pages has a very large wrecker listing for australia/Jap imports etc if you actually have a look :)
Has anyone used hose fabricating places to make the coolant and oil lines to the turbos on a GTR?
I tried enzed and they said they couldn't do it but I get the impression he just didn't wanna do it. Anyone tried enzed or any preferred hose fabricators?
Im hoping to get braided teflon coated lines and was just wondering if anyone has any good places
Ok guys... please dont laugh, my wallet is in too much pain at the moment
enzed wouldn't touch it, another hose repairer we use at work wouldn't go anywhere near it.. and after some convincing, I finally got pirtek to make teflon coated braided hose for $850 for 4 coolant, and 2 oil hoses... it looks pretty cool, and all fits perfectly with the hks gt-ss and the dump pipes but OUCH...
I think the next upgrade to my gtr will probably require me to sell an organ, anyone know what a used kidney is worth? How about a liver?
I will check with my friend when i receive mine and get them made up if the price is right.
850 is crazy!
so very crazy unless they are using all earls fittings and braided hose etc like whats on Dirtgarages car. then 800 would seem about right..
well when you look at its its about 30ish x 8 for the fittings for the water and oil lines, then the lines are around 60 per meter depending on size, then there is any other fittings like bends and such, and if its all speedflow then the adapters for the thread to speedflow.
also, this guy can help with braided lines ect, GT MOTORSPORT, 17 yalgar road kirrawee (the dead end street like 3 factorys up from just jap), 02 95214389
  • 3 weeks later...
  • 3 months later...
I used -6 for the coolant and -4 for oil lines.
I could price it again this is what i used from memory
from coolant block on motor
2 x -6 to m14x1.5 @14
2 x -6 14mm banjos (use std banjo bolts) @20
3 x -6 90 deg braided @ 35
3 x -6 straight braided @ 16
1 x -6 90 deg male male @20
Then the oil side
i think out the block on motor
2 x -4 m12x1.25 @ 15
1 x -4 straight braided @ 20
3 x -4 90 deg braided @ 60 (billet)
2 x -4 M12 banjo @ 20
prices are approximates, but would be close. Be approx 500-600, i was able to get wholesale through speed flow as i buy heaps of this stuff so was alot cheaper, the 60 retail billet -4 goes to 35 wholesale.
Only think you need to check is the metric threads as i cant remember if they are 12 10 14mm etc.
This is only the lines under the turbos, the other coolant lines that go over the turbos i left metal.
Edited by GTR1993
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
