Hey all,
I just got a heap of stuff installed into my 33 GTR.
One of which was a Power FC and controller.
When i look at the controller it reads different to what the standered tacho and speedo reads.
Its around 5 to 10 kmph on the speedo and around 500 in the revs.
Which would be more accurate?
Which would you trust??
https://www.sau.com.au/forums/topic/232801-what-would-you-believe/
Are you 100 % sure on that?
Because id like to keep my shifting under say 7500 to 7000 revs.... and going by the power fc im only changing at around 6500.
And if the fc is wrong and the tacho is right i dont want to let it get around 8000 revs!
If it is the gauges i dont mind. it can stay like it. i look at the power fc most of the time... just making sure thats all.
Will the power fc be as accurate when i put the bigger wheels on? as i know thatll throw out the speedo but will it throw the fc to?
Can I expect this to be the same with my Turbo timer for speed?
up to about 60km/h they are the same but over that and the speed shown on the timer is less than the speed shown on the dash..
I have tried re-calibrating the timer but doesn't seem to help.
The tacho / speedo are basically mechanical displays, and are subject tto inaccuracy through wear-and-tear.
The FC / TT are electronic, and not subject to wear-and-tear.
I would trust the electronic display ahead of the mechanical display.
are you weary of letting it rev to 8000 for reasons of unnecessary engine wear and tear/failure, or because its not power productive to rev it so high?
the stock rev limit is 8000 or so?
I ask as i used to take mine up to 8000 quite frequently, and then a valve guide broke.. related?!
Mine is rev limited at 7000 stock.
my two speedo's used to match up almost perfect. Then after power loss (don't know why, but stereo & TT lost all memory) I could not calibrate the TT which is what leads me to believe that it is wrong?? The power loss has happened twice in 12 months, the first time it calibrated fine, the second just won't work. Any help?
as for bigger wheels, get lower profile tyres and they remain the same size. if u do go bigger i think it is just a minor adjustment to correct the speedo. (just what I was told at the tyre shop a few yrs ago)
i only keep it below that cos of unnecessary engine wear ... but thats just me... i dunno might be safe?
my dash is out aswell, using a consult (group buy lcd consult thing) shows my rpm lower than the dash, yet the same as my automotive multimeter. there old cars now, as stated above the mechanicals in them wear out.
Same with mine.
RPM and speed read lower on my AVCR than on my dash.
Because the AVCR is digitally displaying an electronic signal, it can't really be wrong unless a sensor is giving an innacurate reading (in which case both will be affected)
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
    • Sounds good, we will aim to be there! @The Bogan I'll give you a shout if you are heading up to campbelltown for the meet too.
    • Before I get to the test day, just to finish off the android head unit. This is a demo from car start up....the standard/host system takes a few seconds to boot (same as all v37) but Android comes up quickly. In this vid I'm using the delivered launcher but have set the default to Agami since which is easier to navigate when if use primarily 5 apps. You can see the host system still takes over when required eg putting it in reverse, and you can switch between Android and not by holding the back button 3 sec. It is pretty responsive (fast) but you can see I had to press harder than expected a couple of times.  I still have the phone connected to the stock system, and that also seamlessly takes over Android music playing. v37-android-demo.mp4 The bigger reason that I put this in though is so that I can use Ecutek directly on the head unit. That gives me a dash with logging (up to 20MB only), high and low value warnings on any parameter etc etc. I've run a USB cable from the Ecutek OBD dongle to a USB input on the unit, easy. v37-ecutek-demo.mp4   The unit did freeze on the launcher the other day, I think Agami was trying to verify the license when it didn't have a data connection...will monitor and report back if there are any other problems but so far I'm very happy with the upgrade.
    • Nah that is just crappy GPS mapping, I did have a small excursion (cold tyres, damp track, surprise!), will post up that when I get a chance.
