  • Replies 1.1k
Then changed, derailleur, cassette (again, 11-21t dura-ace this time)....
may i ask why the hell you put a road bike derailleur and cassette on a dirt bike? if you say to save weight i am going to slap you, as there are much better things to spend money on to save weight (things that cost less and will save you more weight)
anywho, here is what my next bike is going to be. hopefully have it by xmas. my mtb is ok for when i got for a ride with cherie, but when i go out for a hardcore sprint around town like i did on saturday arvo it isn't that good. just not quite as comfortable for high speed riding. i just have to sell a bit of stuff to get it.
well its not a mountain/road bike but ill let u all know bout my old sk8park bike!!
its a 2006 DK Cleveland
looks like this
but it looks a lil diff now...
bought it for $700 new
its now got a Hazard light rear rim- $200
tuffneck 3 piece crank- $250
primo rod seat post- $50
primo pedals- $80
DH pig pro bearing set- $75
Dual brake line setup (rear only) whole thing cost around $200-$250
blah
blah
blah
cant b bothered writing it all atm cause i forget. i think im close with most prices...
ill post some pics of my bike up tomorrow!
its for sale too... put a fair bit of money into it back in the day. most top range parts.
looking around $550 for it. perfect for skate park or dirt jumps :(
forgot to take a pic today. been tryin to get the stickers off and make it look good to sell :D
Stagea girl- to my knowledge, mongoose arent really worth much these days unless they're brand new and the higher models. wat is your son planning to use it for? if its for him to just ride around the area or to school then it wouldnt matter if it was old. all you would need to do is spray it(only if needed) and buy some cheap parts. but for a more stressful (on the bike) application such as bmx racing, skateparks or dirt jumps, i would recommend a newer stronger frame otherwise u will just be up for more money wen he starts breaking things :D
think of it as a car. inferior parts= constant replacing, superior parts(unfortunatley more $$$)= stronger and long lasting.
i had my pushbike for a few years and gave it hell. daily use on skateparks with stacks onto concrete from decent heights, landing wrong where ive broke bones instead of parts on the bike, hit trees dirt jumping etc etc... and its still in near perfect condition! because i forked out on the higher quality, i havent needed to replace anything since i upgraded the different parts.
well im ranting on...
Edited by auss13
mongoose aren't worth shit unless they are the ones from the 80's. and if it is a few years old it wouldn't be worth much even if it was a high end model. bikes have changed so much over the past few years, and gotten cheaper. what you used to pay $1000 for about 5 years back you can now get for about half that.
I have an old mongoose frame, was going fix it up for my son, but the bike shop said it wasn't worth it.
Anyone know about mongoose?? They worth anything these days?
If its a Supergoose I'll buy it off you. :D
ok well after looking at the pics, i can tell you that you will be lucky to get $300 for it. sure it might have an odyssey rim on it, and sealed bearing cranks but that is about all that's good. the actual crank arms aren't that good, just the bearings. for $550 you can pretty much buy a 2008 model cleveland, and it is better spec'd. but if you can get $550 for it then well done.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
