I don't if it's just me being a bit naive about the cost of things these days but I feel like I got well and truly ripped for my 100,00km service, i.e timing belt etc, on my S2 RS4.
So how much would you expect to pay for a major service?
In the first instance I will keep the cost and name of mechanic close to my chest but if he has done me over the sh*t will fly.
https://www.sau.com.au/forums/topic/233227-100000-km-service/
Well dont forget that the timing belt should be done around that time too- so that
can add greatly to the over all cost- perhaps you should list what WAS done then we can all
have a look then pass judgement-
timing belt would be about $150 for aftermarket, if OEM almost double. - labour would be 2.0 hours at say $180
Lube service would be approx $250 depending on oils used (assuming engine and transfer and diffs)
At 100k should be coolant and waterpump. If waterpump OEM is $155, coolant is $65, labour on top of timing belt would be another hour so $90.
tune, assuming just a check tune not a dyno, should not be anymore than $100.
so total would be around $1,000.
depends what sparkies he put in? if he put iridium plugs in they are like $30 each so there is a $180 plus half hour to fit.
Air filter - assuming standard panel is (last time I checked) $79 and say 15 minutes to fit.
Fuel filter was $34 and say half hour to fit.
Yeah dood, that seems abit excessive by about $500 odd, did you get an itemised account?
you wont be able to sit down for a month mate, you have been well and truly ass raped if you paid anywhere next to 2k, my bill came to $600ish all oils timing belt water pump labour etc that was about a year ago.
when i got my cooler put on we both came to an idea do half the 100k service now and half later save on cost's ...oil - front diff, rear diff, auto trans oil , engine oil, oil filter, basicall all the fluids that looked old and coulnt wait .. but for that labour was only $240 parts was $148 .. in 6km more im getting timing belt and sparks done and change air filter and maybe fuel filter .. this is at a well reconized workshop also
umm .. I wouldnt agree with 1/2 hr to fit - they can be a b1tch to do as you gotta get SO much stuff out of the way before you do it. And if they were not familiar with an RB25DET it might take em twice that long .
HALF AN HOUR to fit a fuel filter! WTF!! thats a massive ripoff
Did they itemise the bill? if so maybe you could scan in and just blur out the workshop name.
2k - whoa baby! thats good motivation to learn to do it yourlself hey?
timing belts terrify me too - but apparently if you get the thing set up ok and obey the rules - ie keep an eye on where the pulleys are pointing etc- then your ok
oh well - after the 100thou service you should be able to DIY it and reclaim the 2k
Hell yeah, as of yesterday I have got myself a weekender in my mates workshop... I usually do my own services but when it came to timing belt etc I just cbf. Looks like I learnt a lesson the hard way.
Just thought I'd say that I got a quote from a reputable workshop in Adelaide who do a lot of work on imports and they said ~$1,250 (I can't remember the exact price, but it was around there).
This for a series 2 RS-Four V (auto), and they said everything got changed - plugs, fluids (diffs, auto, brake fluid) air cleaner, fuel filter, spark plugs, timing belt, idler & tensioner pulleys & water pump... I must say, considering the cost of components to do it yourself anyway, I'm still thinking about it... I know I can do it 'cause I've had it far enough apart before, but I just don't know if I can justify the time. Plus I could get them to do a couple of extra things like replace the exhaust manifold gasket and studs, checkout the manifold for cracks for hopefully not too much extra while they're there...
I dont get this myself, I mean, if you are confident enough to remove the spark plugs you have all the skills required to change a timing belt, and it doesn't take that long really.
The ONLY golden rule to stress about is making sure the crank/cams aren't rotated if the timing belt is off, other than that, it is really simple to do.
Best way to learn is by doing.
Mine was almost $2500... :P but I had a cracked exhaust manifold (with 4 broken studs) and leaking main seal etc.. <sigh> But it was a new car afterwards. Had the usual work done with water pump, thermostat, plugs, timing belt (racing one) plus had engine mounts done, all acc. belts, vacuum hoses etc etc etc..
I have to get mine done soon too, is this Boostworx?
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
