It is bro. Dats the chargespeed rear wid the cf rear diffuser. Im getting that rear but i need to save up 1st as i still have a lot of expenseswid my wheels ariving late this month. The trunk is called a doriluxe trunk but is only available in the U.S
Damn - well I'm not thinking of spending any $$$ on the V this year so when the time comes next year might try to see if I can source that bood lid :)
Post up pics of your car with the Varianzas when they come - a huge fan of those wheels!
Was thinking about my dyno run figured out the answer - mine is an auto. I think you would expect a 10% difference between auto and manuals .... mind you would still like to see some stock auto dynos of other V35s to compare.
I've got a 5AT. When it was stock it ran 210rwhp (~156kW).
I've had around 5 dyno runs on 2 different Dynos after I got my mods. Don't have the printouts but the max I got was 233.6rwhp (~174kW) and the min I got was 224.2 (~167kW) - both obviously on different dynos. The Dyno used for the stock reading was a different one to the ones used after the mods.
My mods are:
- Ztube
- Stillen Airbox
- Kinetix V+ Plenum spacer
- HFC
Some of mine from the Extreme Horsepower show here in Adelaide last weekend .... and I picked up the "Highest horsepower 6cyl n/a" trophy for my 148.6rwkw dyno run.
53641B95A3AF4899A7EE0779A340CFA1-0000327810-0002006430-01024L-BE6629F164724D4297627648E40855E7.jpg
BE3E4BB452EA4111ABA7F1D52E7F022A-0000327810-0002006435-01024L-167ABE17A31A490ABC58D7F0374D95A4.jpg
More pics of my car and various cars in the show here (click)
All I see are legs :D
Damn thats nice XTC..The car aint bad either !. Lol.. I mean move them bitches out the way.Their spoiling the look of the V. Like I keep saying.Black is Sex on Wheels in the V. And that Lip spoiler is the best I've seen.Fan..bloody tastic.
Now thats what I'm talkin about guys keep them pics a rolling !! :ermm:
Edited by ELFGT350
Nice...both the ride and the girls. :ermm:
Victor.T, pretty sure thats a vinyl wrap, lots of people have jumped on the wagon to do it!
Looks the goods, and seems to be reasonably cheap if you do it yourself. Obviously time consuming thou.
Ill Take Pics of My V once the wheels are on!
Right. I thought so too after I posted. :P
Sure. Do post up more photos afterwards.
Edited by Victor.T
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
