Don't know why people have been hating on the oil cooler, as long as it's actually working then who cares.. it looks good and i don't think i've ever seen one on a V35. Chris, you're boosted right?
I have an oil cooler - but it is tucked up nice and neatly behind the front bar on the drivers side (had to lose my window washer bottle though).
Yep, despite having owned a modified S15, R34 and now V35, I have NEVER been to Regency :) ..... you only go there if you get defected.
Who's palms have you greased! Geez! My brother lives down there and said that people tend not to sell their OEM parts because they need them for regency. Apparently sodomy is quite common over there. :/
Yeah I keep all my stock parts and always have. But I don't drive like a dickhead, don't drive on bald tyres and keep my car pretty clean and tidy. Doesn't hurt that I am a bit older than your average Skyline driver .... also doesn't hurt that I am not out cruising the Bay or the City every Fri/Sat night, and don't hang out at known drift/meet spots - these are where quite a lot of defect occur.
^^ exactly. Another reason why I also avoid organised cruises
Police see event cruises, night driving, driving in crowded areas with windows down... as being for entertainment only and therefore a public niusance. driving here now is nothing like it was in the 90's.
Edited by Deep Dish V35
^^^ depends on who is organising the cruise though - tomorrow night's BSM cruise will have something like 500+ cars at it, yet will be completely police friendly and they DO NOT pick on cars on the cruise unless you have very BLATANT illegal mods or are acting like a d!ckhead. You should come along! Melzi is coming.
Used to be boosted.
Ahh... maybe one day again. Look at turbo kits all the time, lol. Ordering another cup kit. Finishing the exhaust. When that's all done I'll either decide to keep the cooler for a long time or just throw it away (because I really don't think I'll ever need it... even when boosted again).
I'm the kinda person I don't know if I like it until I actually see it. So I always buy stupid crap just to play with and then sell or chunk.
Just look at this old picture :wacko: :unsure:
e66806af.jpg?t=1314689749
Edited by SleepyRN
I have 275s on 10" +12 rims hanging out my back guards, low front and rear bars, dark tint, noisy exhaust, and I use my car daily for work (30,000km a year) and in nearly 3.5 years am yet to be pulled over :)
However in my old R34 and S15 before that used to get pulled over regularly.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
