Nice car there Mat! Is Kristian organising compliance for you interstate, or are you doing it here? If you need to borrow some stock rims to get it through let me know and you can borrow my stockies.
Cheers Andrew! Thanks for the offer :) I'm pretty sure he's organizing it interstate I think but if he does it here I'll let you know!
All 4 wheels are on now and I am fairly happy with the result, Rears do tuck in a fair bit but after all they where brought for my old maxima. Might look at lowering it onto 350z springs next and then might consider buying a new set of wheels to fit the car a bit better.P4110925_zps692ce8f3.jpg
  • 3 weeks later...
^^ I look forward to selling you a Urethane Nismo front bumper bar very soon when you break your lip and rip your stock bar off :) .... the low life sucks without Urethane - I bend and scrape mine all the time and it just pops back into shape :) :) :)
  • 3 weeks later...
Hi guys, one of my mates wants to get a V35 as well seeing mine. We went to Nagoya motors near Sutherland, NSW and saw quite a few V35s in different colors. I was surprised at the price as it seemed too low for the low kilometers. Most of them had around 40k-50k kms, where as I got my V35 a few weeks back from a different dealer but reliable and who i personally know, a few grand pricier with much higher kms (80k) with genuine japanese documents. (although mine did come with HID xenon lights and Fujitsubu performance exhaust). My understanding was that cars with such low kms would be quite expensive and not definitely $15k-$16k. Prestige imports who only import cars on order basis (they only collect the agency fee, everything else is paid by buyer) told me that genuine cars with such low KMs would cost higher in the auction and as a result the final price paid in Australia would be much higher. I wonder if those cars at Nagoya motors are clocked back.
Edited by saif22
I had a similar experience when shopping around for my V36. Some incredibly low kms (27,000 in one instance), but no paperwork to prove the veracity of the claims. I became wary, especially after reading about how common this 'winding back' of kms is. Finally found Road & Track in Silverwater, Sydney. The manager there, Gavin, only sells cars with all of the relevant Japanese paperwork. Provides much more comfort when laying out a significant sum of money!
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
