  • Replies 174
Posted Images
you would think atleast he would have a shave
The poor bastard probably hasn't had time for a shave i would say some one has been keeping him busy building their car for them while they supervise whilst sipping bourbons :banana:
looks good mate. it will be even better now that Beer Baron super express racing parts has got you those mines front rotors. :) cracked rotor in an R35 going hard would not end pretty....
Man you are going to have a ball in it now. all the little changes like the moveable paddles, the wheel, the seat and harness will make a huge difference to the feel of the thing.
I also spy you with some maccas in the first pic. food of champions! hehe.
I was just remembering back to when I picked this car up from the docks in sydney. brand spanking new, plastic on everything, 100kms on the clock.... look at it now! thoroughly abused!! holes in it everywhere, caged, stripped, seats, steering wheel, exhaust... but it's been set free from a life of posing at coffee shops and fancy hotels. we both know it's much more at home out in the boonies at some race track belting out some laps. you've set it free mate. haha.
my mate justin who was there when it arrived in sydney all those months ago saw the pics of it last night and he nearly didn't beleive me it was the same car!! poor fella was beside himself as it's by far the nicest car he's been in. he can't understand how we can do things like this to perfectly good forms of transport.
now go and kick some arse in tassie. :thumbsup: and most importantly have some fun. but if you can get a result it would be nice mate as at least then mark will stop lauging at you. I can even see him laughing at your car in the last pic. gold!
I see Drew and Georgie have entered this event as well. They are the ultimate quiet acheivers in that little R32 GTR of theirs. Their car is pretty much what I'm basing mine on as far as set-up goes. It's a sweet little ride.
Into Burnie mate............
Fantastic, I'll keep an eye out for it on Wednesday.
If he (or any Skyline pilot for that matter!) needs to use a hoist at all while he's here give me a yell, I'm right in the middle of town.
Do you know if we're allowed to transport fuel drums on the Burnie ship? wanting to bring mainland BP 98 over in the ute......
What's wrong with our BP98? :) Don't know, best bet is to give TOLL Shipping a call.
    • I saw you mention this earlier and it raised a red flag, but I couldn't believe it was real. Yes, the vacuum signal should vary. It is the one and only load signal from the engine to the ECU, and it MUST vary. It is either not connected or is badly f**ked up in some way.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
