so going from stock, what diameter would be best suited as an upgrade for an R32GTST?
currently have coilvoers, adjustable upper arms and am getting castor rods in this week - hoping to install the castor rods and sway bars at the same time but i don't know much about suspension.
What type and diamter are you guys running on your R32 gtst's? And what diameter are the stock ones?
cheers
  • Replies 44
hahaha, The whiteline factory is only 2km away from my house on the C coast. :banana:
im getting
Swaybar - Extra Heavy duty blade adjustable 22m (front) =$195
Swaybar - Extra Heavy duty blade adjustable 22m (rear) =$220.50
Swaybar link kit - Spherical rod end (front) =$117
Swaybar link kit - Spherical rod end (rear) =$153
Seeing as its a GTS-4 i had to get all the GTR products but its still cheap.
getting the top of the line swaybars and links. Because of the discount it makes it that cheap and there standard swaybars and links cost more than the price im getting there best ones for :D
I keep hearing better stuff and even more popularity with whiteline nowdays.
hahaha, The whiteline factory is only 2km away from my house on the C coast. :(
im getting
getting the top of the line swaybars and links. Because of the discount it makes it that cheap and there standard swaybars and links cost more than the price im getting there best ones for :)
im assuming this would suit 32R as well?? do u need the link kit??
(SAME AS THE R33 GTR AND GTS-4)
Swaybar - Extra Heavy duty blade adjustable 22m (front) BNF27Z
Swaybar link kit - Spherical rod end (front) KLC008
Swaybar link kit - Spherical rod end (rear) KLC009
(THE ONLY THING DIFFERENCE IS THE REAR SWAYBAR, ITS MADE IN A SIZE 24mm ONLY SO YOU WILL HAVE 22mm ON THE FRONT AND 24mm ON THE BACK)
Swaybar - Extra Heavy duty blade adjustable 24m (rear) BNR26XZ
  • 4 weeks later...
  • 3 months later...
I don't think you do ...just checked the web site and it states those parts are for "RACE USE ONLY".
What's the price difference between the adjustable and non-adjustable, does anyone know? Is it worth the extra dough for the adjustable ones? Somehow I suspect once these things are on the car most people would never "adjust" anything..
edit: NO price diff for adj./non adjs apparently according to web site, $229 for a GTT front sway bar + gst.
hahaha, The whiteline factory is only 2km away from my house on the C coast. :D
im getting
getting the top of the line swaybars and links. Because of the discount it makes it that cheap and there standard swaybars and links cost more than the price im getting there best ones for :banana:
That's only a warehouse at Somersby, the swaybars aren't manufactured there.
The rear at 22 mm is too small, I always use a 24 mm on the 4wd's
Make sure to fit the dust covers plus greaze and regularly service the spherical links, otherwise they will wear out very fast and knock like crazy.
Cheers
Gary
I need an honest opinion here... would swaybars improve handling for a daily? Or is it only for maniacs who like to take every single corner at high speed?
ABSOLUTELY they improve handling for a daily. They're the best bang for buck handling mod IMO.
u will notice the car sitting a lot more flat, the ride wont be compromised, but in tight parking situations with unlevel ground u will notice more inside wheel lift and the wheel spinning freely (unless u have a mech LSD or locker)
another question: ive picked up a set of sway bars(front seems to be 27mm, rear about 24mm) the on the rear part where it bolts to what i call the link, is vertical rather than horizontal. is there somesort of link kit for this, or have i just got the wrong one. The part came off a 2 door r33, trying to fit to r33 4 door.
what about bumps/potholes though on a daily ? My understanding of the way antisway bars work is if you hit a pot hole say mid roundabout it would be worse than without them ? Happens a lot in the inner city ..seems whenever I turn, wherever I turn there are friggin potholes
You have a shock absorber problem not a swaybar problem.
Cheers
Gary
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
