  • Replies 72
as unlikely as it sounds but a broken ringland/piston can cause a miss under load.
whats ur fuel pressure regulator like?
a flogged out dirty catalytic converter also can cause problems.
this happened to me , i had a dry solder joint alomg my loom , midway along it too mind you , absolute prick to find.
could be that
Hi I am new in the forum and I have the same problem. My car is R33 GTS-T 25T Series 1 Auto. I recently increased boost to 12 pounds and started to experience misfire only at full throttle (the car has a pod filter, cat-back 3" exhaust, Unichip, bleed valve and standard everything else).
I took my car to Nissan yesterday and fitted a new set of standard heat range 6, NGK Platinum plugs (previously Greddy Iridium, heat range 7), which improved the misfire problem a bit. However, idle rev has gone up from 660rpm to 760rpm.
Any thoughts will be much appreciated.
Gday Kymmy!
sounds like over fuel for sure...
same rev range same boost range...
yeeeeep
Originally posted by Strich9ine
Cheers guys,
Well, I'll just wait until the AFC is in and tuned, and if it still does it, i'll be looking at the AFM.... daym!
Maybe it's better to go for a Z32 AFM ? How much are they in comparison to a stock AFM ?
crooser,
By single misfire, i mean, it gives about 3-4 big pops consistantly between 4000rpm and 5000rpm.. then power comes back on after 5000 and it runs fine till redline...
so frustrating...
  • 4 weeks later...
After a full major service today thinking my misfiring/poping would disappper has not helped.
i ran 14psi on my r33 series 1 at 4000 - 5000 rpm she would misfire bad. I got a pod, highflow cat, 3'' exhaust system and a custom fmic. As a result i have to run the factory boost level to avoid this problem.
Anyone got definate solution to this nightmare we are all having.
Well heres my plan of attack in the next few weeks and will update this post with results.
1. Coils (another pair)
2. SAFC
3. Z32 AFM
4. Electronic boost controller (I might have a faulty bleed value_
If it doesnt get better im gona go nuts. any comment welcome as im runnng out of ideas
Thanks in advance
AK
As a last ditch effort, look at higher energy ignition.
I admit I know nothing about MSD type units - in fact I was surprised to see someone on this forum revert back to a VL style "distributor cap and 6 wire" type setup.
However some people have gone to Splitfire D1 coils and this solved their problem.
But they aren't cheap.
T.
Has anybody thought that maybe it may be a faulty injector/dirty injector??? An injector could be dirty and staying open a little possibly and causing overfueling in a cyliner. One of my plugs was blacker than the rest so im getting my injectors checked.
HI WLD747, have you got a boost cut defeater? We have 700 bhp RB's running 1.5 bar with standard ignition, I don't think you need to look at upgrading.
Have not read the above threads so maybe i should keep my mouth shut but I like almost everybody on this forum have had flat spots like you!
I started a thread: http://www.skylinesaustralia.com/forums/sh...&threadid=23922
and got lots of suggestion most of which were fuel related!
All r33's are going to get a small flat when the cam changes position around 4500 revs. And a fuel modifier like a s afc or something should fix that. But if you are getting really bad ones then you should not rule out the air flow meter, ignitor pack or spark gap...
Spark gap has probably been suggested already but I had somebody change my gap from .80 to .76 which totally fixed the problem, so even the slightest change in gap can make a difference. I should also mention that I am running NGK iriduims.
Have a look at the link above there might be some suggestions there that could also help you!
Sump Baffels? Wtf?
Anyone had the ignition module (black box on top of the engine) die on them?
I've got similar engine skipping problems, and after trying everything else, I'm thinking that may be the cause
rev210 is right the problem is ignition.
This fix has worked on 3 out of 4 cars that I have tryed it on including mine and hitnrun's cars,
Croosers car being the one that it didnt work for (he had a stuffed Afm).
Advance the ignition timing from 15 deg to about 22 deg. no more than 25 deg and then reset the ecu.
Regards
Damqik
Gunmetal has the right idea and I second his post re: .74mm gap with stock ECU on upped boost. check this thread, I just went thru the same BS and sorted it.
http://www.skylinesaustralia.com/forums/sh...5648#post555648
wishing you a speedy recovery !
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
