Hey guys,
Im getting pissed with this engine problem, Ive put it off until now but now its just painful. Just so you know I had my belts changed along with a endless amount of parts so its hard to pinpoint the issue.
The problem is a slow start every time I park the car and turn it off for 1-5 hours more than that and it has no issue starting. The engine will take 4-6 seconds to fire and I will try ignite, stop and go again more often than not its 3 attempts to turn it over. This then greats me with a mid idle not the typical starting warm up idle. It can often just fire cylinders slowly as if cylinders ignite one by one very slowly.
Saying this when I walk out to start the car in the am before work she fires with no issue.??!
Im aiming at a few items.
Alternator - Its an R34 alternator so I find this hard to believe, I had no issues before this time and the car will not stall and holds a steady charge even when sound system is thumping for 30mins or so.. I dont feel that it can be faulty if its still doing its job.
Starter - The clutch was changed in this procedure so Im thinking it may be this, How extactly do these work could it perhaps be a weak voltage drop to this item?
Belts - I fitted gates belts when I start the car I notice the power slowly raises stops then continues from 12v to 14.8 or close Im thinking when cold they shrink which is great for long term in the short term they sqeek so loudly when it fires and are so tight they dont spin correctly on ignition. Perhaps they are stopping it cranking correctly.
So Fuel pump, installed it when stock had no issues like this. Eliminated.
Injectors - checked
Sparks - Brand new powered with spitfires.
So my money is on starter but what does someone else think?
https://www.sau.com.au/forums/topic/236202-slow-starting-engine/
not good Nath :)
hope you find the prob soon!
just wondering... is it only the gates belts that shrink that much? or do standard ones do it to?
cause i was going to get gates belts all round but after reading that they dont sound too well...?
cheers mate
Jaye
This might sound crazy... What brand/type of oil do you use? Sounds exactly like a problem on my dad's VS commodore. He had the problem when he was used Pennzoil semi synthetic, so far all other oils he has used do not seem to give a problem, might be worth a look.
Further investigation on other vehicles suggests its a rooted starter.
How do starters work as im expecting the cable to badly connected or similar. I know they would be grounded and positive somewhere its just checking connections.
Supposedly the starter requires more power when it absorbs heat, this inturn needs a bigger current when warm which it cant draw because of either clutch dust or bad connections. The reason it wont start when stopped for the first hour is because the heatsheild blocks most heat but cant resist it for more than 30 mins or so.
Sounds like total crap I know but its actually true, alot of people have exactly the same problem in almost every single car even out of factory brand new!
Now I just need spare time and a hoist.
Crap!
I would say from listening to the problem, it COULD be the battery very possible although its highly unlikely.
I would put my money on the starter motor though bit odd only starting from cold though, woulda thought it would be the otherway around.. awell hope its fixed asap.
my first thought was too far advanced timing
but then you said that it was a warm start problem
i think it might be a combination of what lunjiaow (vince) said and what ive said
(sometimes a hard start is too advanced timing - a very easy start is timing too retarded)
  • 8 months later...
  • 2 years later...
Have you changed the timing belt recently? If so, did it start doing it afterwards?
I have the same issue, picked up a 34 gt, the timing belt was done 5 weeks ago (before I picked it up). Ive been looking over the same things and none have fixed the issue. However, looking at the CAS the previous owner has marked it but it doesnt look to be correctly aligned with the marks, but not sure on this as the marks were made on the washer......
It seems to be in an advanced position.
I dont think its anything to do with solenoids or batteries. The rb25s are all built the same. The series 2 doesnt have this problem. It seems to be a regular occurance on the neos. They start fine cold but when warm sound like they want to start but just dont as if no fuel or spark is present. I think it has something to do with the neos design or tune.
    • 3 Kids are starting to hit that ages. I wanted to get them something special to learn on, put down the screens and have some fun. 4Door 2001 R34DE Black Pearl GV1 Jap Import, AU 2nd owner. Pre Work done. Suspension - Wheels Pedders SportsRyder Coilovers   Wheels TSG Spokey Boi 18'x9.5"+15 Body JASI Aero 4 door Type R Full Kit LED Conversion - Parker, Blinkers, & Reverse Exhaust Hurricane Headers 100 CPI high flow cat 2.5" Piping Cannon muffler Internal Bride low max stradia ii - front seats  Bride RO seat base and Rails (R/H) Cube short shifter LED Conversion - Interior
    • Why are you so adamant on going M12? Why not follow Brad (GTSBoy) suggestion. You're talking moving from a 1/8" size, to a 1/2" effectively. 4 times bigger. Why skip the commonly available sizes in between? The bigger you go, the more likely you are to strip the threads out at a later date, as guaranteed, someone will put a huge spanner on the M12 and really tighten it up, and you're only in thin wall, so not a lot of threads to engage!
    • Hi. Yeah thanks. Car is already at tuners and it staying there to resolve "many" issues they do not like. So it is in a good hands. Getting a good tune on that Nistune ECU too so the car would be good. Just needs a little tune up and love.
    • Probably gonna remove manifold and turbo. I’m not sure if I can get M12 x 1.5 air tight. Could use high temp Loctite 246 or something similar, but I don’t know. Maybe it’s just best to remove everything again and weld an 1/8NPT on there instead.
    • Yeah, saw the ratios, not impressed. Would like the punch I have in the first gears now. With those ratios it won't be the same.  Also want the h pattern gearing, or at least a quiet gear set that don't need to come apart for service each year. Looks like the only "reasonable" way Is a 8hp70 transmission, but where is the fun in that🤷‍♂️
