Morwell - Sat 11 Oct - Sau Vic Club C/ship - Rnd 7
Here are the Supp Regs and Entry form for Haunted Hills.
Supp Regs - http://www.wrx.com.au/motorsport/Supp_Regs...s_11-Oct-08.pdf
Entry Form - http://www.wrx.com.au/motorsport/Entry_For...s_11-Oct-08.pdf
Once you have entered, please check you are included on the ENTRY LIST.
It will be run under AASA.
It will run in a clockwise direction.
There will be canteen facilities available.
It is one and a quarter hours from Dandenong.
There will be 2 cars on the tack at one time. One car 30+ seconds behind the other.
There is a pit lane area. If you are bringing a trailer please don’t unload on the hotmix surface. Hopefully there will be signs by then.
The WRX Club need help in the following areas, so if you are available please contact Lyn from the WRX Club, or PM me your interest and contact number or email address and I will pass on to her for you.
1 pit marshall
1 start line
1 turn 7
1 turn 15
1 rescue vehicle perhaps with trailer
Cheers,
B
  • Replies 68
You don't need serious brakes. I'm not sure how quick the track is but you probably won't be seeing much over 100 and you only do one pass at a time. The old morwell track wouldn't even get your brakes up to temp!
It's not too quick from the videos, but it is fairly steep. They're not in the best shape at the moment, so the day would screw them I reckon. They're really not very good brakes at all!
Im sure most have seen this by now, but for those who havnt:
name="allowFullScreen" value="true"></param><embed src="
type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>&">
type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>&" type="application/x-shockwave-flash" wmode="transparent" width="425" height="350" />
it looks very clubsport friendly :)
i found that at the old morwell, without abs, the brakes got off so lightly because it would take so little to lock a wheel. just take your abs fuse out!
Fark, I'm tempted! I just got a new clutch this week too... hmmmmm
You're right about locking up the wheels at Morwell Ryan, but this looks a hell of a lot smoother than that was and at least my street tyres should come up to temp quicker... before I fly off the track in a haze of dirt :dry:
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
