  • Replies 80
Well yer, that one is one of only a few hundred made ( 3.6 litre single turbo ) so might be a wee bit out of the price range. But i know that the C2 is within your budget.
They are a very sweet car to drive still prone to the lift off over steer as old porkers are but a more nimble car is hard to find i think you would enjoy the drive most people i have in the car do. and if you want to buy it mate i can fit you into slot 59 on the to buy list :-)
And yer on the right track with the lotus we are just about to convert an S1 elise into a exsige with the K20 honda conversion kit, infact engine was delivered yesterday. That is going to be our 24 hour race car in class 3
LOL, i am yet to have somebody link me to a race classified website that i have not stumbled accross in my years of dreaming. That one is my particular favourite for Grp A Sierras and GT2/3 Porkas :)
Group A is for pussies.
What you need is an RS200.
There are six of them here:
http://www.anamera.com/en/find/list/index.html?no_cache=1
as much as I reckon the maclaren would be right up troys alley, I like him the way he is now..... alive.
I'll let him have himself an shelby mustang GT500 though. they don't list a price so it must be super cheap....lol
http://www.anamera.com/en/detail/car/6754/...he=1&ret=63
Troy will be fine. Just remind him to clip the rear body work on properly. As an aside did you realise that Jimmy Stone (of SBR fame) used to work on the McLaren Can-Am cars. He was there that awful day....
Yeah POA is a euphamism for cheap.
Maybe just buy a new shell. Seriously - new.
http://www.dynacornclassicbodies.com/classic2.html
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
