  • Replies 99
Sly33.. can i ask what mods have you done to your car??
the reason being is i too am chasing around 230rwkw and am just interested to see what the difference is between 230rwkw and my failry stock car.
wouldnt mind going for a spin in your car either if thats cool..
give me a holla when you up in Sydney.
https://www.sau.com.au/forums/topic/2381-hks-turbo/page/3/#findComment-432464
Recently put a HKS GT2540 in my GTS-t and am very happy with it - it is only really used as a street car. And yes while the peak power gains are not massive when considering what standard turbos can reach, you can play with higher boost figures consistently without worrying about the turbo giving up on you...
Power figures aren't mind-blowing but as a few people have already noted, it's not often you'll need 250+ rwkw's on the street...
https://www.sau.com.au/forums/topic/2381-hks-turbo/page/3/#findComment-432528
I know of someone who is doing a Garrett setup (600hp turbo) which basically will be the same as my 2835 pro setup bar maybe a plenum and Microtech V PFC. We and sure everyone of you will be keen to see the results. I will keep you posted. By the way 2835 Pro is a T3 flange for whoever asked.
https://www.sau.com.au/forums/topic/2381-hks-turbo/page/3/#findComment-432556
EVOIV,
I've been more than happy with the e-Manage. As long as you purchase all the harnessess as well, gives you good tuning scope. Though seeing as it's essentially still a piggy-back system, not quite as comprehensive as the A'pexi Power FC.
As I have the e-01 boost controller / monitor it can be tuned via the hand controller, though again, with the support CD and cable it can be hooked up to a laptop as well for greater ease of use.
All in all I think very good for the money... can't remember exactly how much I paid (bought all my parts in the one go), maybe round $700 with the harnesses (excluding e-01 unit)? Not too sure... can find out if you're keen.
https://www.sau.com.au/forums/topic/2381-hks-turbo/page/3/#findComment-432573
well its not making the 230 yet as the turbo is still waiting to go on.
I have the usual full exhaust and intake mods, decent FMIC, extreme clutch, bosch 044 fuel pump, power FC computer. This got me 200rwkw. All i need for 230rwkw is a rising rate reg. and a retune of the FC. Although i may splash out on 550cc injectors just for peace of mind that no leaning out will occur.
Ezekrael you have a fair bit more potential in your setup!
https://www.sau.com.au/forums/topic/2381-hks-turbo/page/3/#findComment-432665
Freebaggin,
I saw the Dyno chart on the computer @ the workshop, but their printer was stuffed on the day... so they're printing it and sending it to me in the next few days.
212 was the best repeatable result they could manage cuz the factory clutch was slipping more and more with each run... they got up to about 230-235 rwkw @ around 1.15 bar I believe. We'll know for sure when I work out what clutch to go for, any suggestions for someone aiming for 240 rwkw guys? Don't want anything too savage... Been told to go for Exedy so far...
Sly33,
Sounds like we've got very similar setups... I've got A'pexi GTspec FMIC, pod filter, bosch044 pump, Nismo 555cc injectors... hopefully with decent clutch, should be good for 1.2 bar and 240 rwkw? Who knows... :P
https://www.sau.com.au/forums/topic/2381-hks-turbo/page/3/#findComment-432870
Just wondering if you guys 044 fuel pump is mounted internally or externally? I used to mount mine externally, and put rubber/foam between the fuel pump and the car body and it was still DAMN loud from inside the car! Gets kinda annoying after a while. A constant buzzing. Can you place this fuel pump inside the fuel tank? If so, can you still hear it?
Are the standard skyline turbos good for 230rwkw?
https://www.sau.com.au/forums/topic/2381-hks-turbo/page/3/#findComment-433577
Having driven a 4wd car with around 500hp and also driven a rwd car with pretty good power I can safely say that for a street driven rwd car you don't want a peaky turbo ie one that spools up at 3500rpm and hits hard.
All you'll get is wheel spin in first and second if your not careful.
The 4wd is a totally different story. Traction is much less of an issue, so you can launch it at 4500rpm with a slight chirp and your off.
So for a street driven rwd car you want a nice wide usable power band that starts low and has good torque spread.
J
https://www.sau.com.au/forums/topic/2381-hks-turbo/page/3/#findComment-433630
    • Saw this video today from Adam LZ.    Long story short is he is claiming that the load from the engine fan once the fan clutch heats up(engaged) is increasing the getrag rattle(at idle) when you don't have a dual mass flywheel.  Before I go buying an electric fan setup .... Anyone heard of this ?    I must admit when my car is cold the getrag is pretty quiet and I do notice the rattle after it is all warmed up. I've always assumed this is due to the gearbox oil temp and tolerances of metal.
    • Yep it sure does.   Tone wheel lines up in the same spot perfectly.
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
