lol, actually, we are both off, its $10,387.87 for the whole kit, you must have missed a piece lol
the kit is made up of...
Side Skirts - AUD 1550.08
Rear Bar - AUD 1642.63
Wide Rear Guards - AUD 1935.23
Wide front guards - AUD 1739.47
Front bar - AUD 2098.90
Front bar Lip - AUD 1403.56
totalling AUD 10,387.87 shipped.
see link below for each part
cross factory kit from rhd!
Jesus H. Christ that kit's worth almost as much as the car :P
  • 2 months later...
anybody know where to get that west yokohama kit from?
googled it, cant find anything
Hey, If your just after that front bumper, a person sells its on ebay.
I bought one off him, great fit
But i modded the grill part a little to get a grill going on.
Heres the link to ebay: West Yokohama GTR bumper
here is what it looks like atm on my car:
Bumper with Original Grill: cimg0676y.jpg
Here is what it looks like with Mods in the Grill Section:cimg0705iv.jpg
im hoping someone might be able to help. im looking for the factory optioned r34 aero lip, i attached a pic. also was wondering does anyone know how much lower they sit because i want one to cover my intercooler piping because i have a turn flow intercooler, then i can cover it up with the hard plastic underneath to protect it from any damage.
i think under the skylines australia wa for sale autoworx has a thread on r34 bodykits, dont know if they still sell it any more though, but i did see it on there, heres the link
http://www.skylinesaustralia.com/forums/R3...ff-t221114.html
that what ur after?
250 bucks ...
heres a link to the optional factory aero kit i think? not too sure what its called but its nismo or something .
http://www.vivagarage.com.au/nissan/nissan..._aeroparts.html
same look down the bottom but even nicer than factory front bumper imo
280 bucks, not much difference
about the same price, autoworx is pretty far from melb unfortunately, its where i am in WA, not too sure where you can get it from in melbs. viva is in SA.
doesnt really look that low on the pic, but ive never seen a kit like that in person, but the nismo kit doesnt sit very low (i test drove a 34 with one of these kits xD)
hope that helps
im glad to c that my kit is not on there, apparently there are only a couple in australia with the same one.
its a genuine tommy kaira front bar (when we fitted the cooler my mechanic was full sweating bad because he knew we cant replace it lol)
on the tommy kaira website it said that they wont ship to australia because i want the side skirts and the rear bar but i dont think i will ever get them
ill add pics on the week end when i clean it.
  • 3 weeks later...
^^ That nur coloured GTT has a modified veilside GTR kit.. typical veilside style :D the top secret CF bonnet and rear wing is nice
That's a very sharp pair of eyes mate. Anyway the GT wing now has changed. will post up the pics soon. Kinda wild compare to the Veilside one.
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
