  • Replies 130
Don't be scared, we don't bite :P
HEY! Speak for yoursel.....wait what were talking about....oh nvm
thinking about it, but i don't know anyone and not too keen on duck :P
alright, i guess its a meet and greet so i'll see u's hopefully
Man it's prob the best way to meet new people so far I've only been to one meet and so far everyone is nicer then family....(this is comparing everyone to my older brother of course)
Also like to thank everyone for correcting my list, my edit permissions have not expired so I cant change it anymore but I think it should be good until the meet....which is in 3 hours BOOYA!
bring the jazz. have some fun. put it amongst 10 skylines and u wont even notice it there in a pic. lol.
hahaha nah man....jazz is only daily/work car. And only take it to annoy the missus :P
damn missing out mah man
OHHH See I miss read your post it wasn't my fault I swear AP it wasn't anything personal....well not yet since apparently you have "FRIENDS" hahah
Great meet up last night.
Where did all the West Side ppl go? Did you all just leave early?
Duck was so good and didn't leave the car park till around 12am talking to llama au, Kas180 and JamesK.
Was good talking to you all!
We need a translator next time we go to that place. We clearly asked for 5 x 1/2 duck and rice. And they just gave us the normal duck on rice.
I knew that'd happen when he repeated back "duck on rice" and no-one corrected him :(
Haha did you think i understood him? :) Was quite loud when we all got in there hahaha, they actually told us to quiet down lol
Dude 3 "Asians" were there and no one spoke chinese....I doubt were getting a translator any time soon
lol that is so true James, off you go to learn so you can be our translator :)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
