I would be tempted to fit bigger injectors and lean on the stock turbo a bit. The e85 will give you more power whilst running lower exhaust temps compared to ULP, so it should reduce the heat load on the exhaust wheel. I wouldnt be surprised to see 220rwkw at 15 psi with a stocker on e85
Ok last question.
After the injectors are installed, a decent tuner should take how many hours to do a full map on e85? keeping in mind I have it tuned on 98 at the moment. Plus I read that fuel filters were getting changed every few weeks for a while after is that true?
Apart from that all else should be sweet though right.
Its all the same stuff.
E85 either comes from CSR or Manildra. Unless Powerplus are making it themselves which i doubt.
As we were going through installing the new fuel system all parts that were taken off the car were inspected, everything looked great :)
The injector O-rings are not brittle and have no sign of cracks or premature wear at all. I was comparing them to a new set that i have and i cannot tell the difference between the two.
To save you scrolling up on this page, here it is again :bunny:
Mines not the injector O rings that are the problem, rather the O ring between the fuel filler and the tank has swelled and no longer seals.
The car is a 1990 but even a brand new nissan o ring seems to swell up and fail to seal. Perhaps their manufacturing changed in the r33 series of cars?
didn't bother doing a cold start on mine....
it starts....
eventually
I jack up the cold start enrichment by around 25% at -10C and +10C, then 15% at +30C and finally 10% at +50C. I leave 80C alone, although some guys have found adding 5% works OK there as well.
You might want to have a look at the cranking time, it depends on your injector speed and type. Have a play, you can't hurt anything, after all E85 doesn't contaminate the oil like petrol.
Cheers
Gary
ok
1. gary... you're alive!
2. thanx man, would have a look but the car needs another tune on e85 anyway as we found a split cooler hose was present at the time of the last one... i'll pass those values on to trent.
wonder how much more my injectors have in them..... they were pretty far on 311rwkw with e85 cant remember the max dc atm (not 100 lol), but should be looking @ 325-330rwkw if they can make it...
ok
740's??? mine maxed out at around 335 340rwkw
Haven't been on here for a while and last time i was there was talk of unavailability issues?
How's that all looking now? Who and where's stocking the good stuff?!?!?!?!?! (In Vic)
My car is going in in a month and i sure as hell want a re-tune on E85 but it'll be availability dependant!!!
Cheers!
when i go to hoppers i fill the tank and 2 x 20lt jerry's as well... that's right on $100
i also keep a 20lt sunoco tin with e85 stored on a crate in the garage so that i can change the map to e85 before i leave the house :P
My 555's maxed at 337rwkw on E85...
I have upgraded to 850 Sards and am now seeing anywhere from 80-85 inj duty on my Power FC and making a consistant 350rwkw on E85 with a base pressure of 43.
Your 555's still have more in em on E85 joeyjoejoe imo.
Maybe the 2 Mainlines and 1 DD were reading high who knows but thats my experience so far.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
