my goodness, you're running semi synth oil on engines like those?
you'll find most guys on here will be running AT LEAST a fully synthetic oil (like 99% of people) of Group IV or higher. A lot of oils unfortunately market themselves as synthetic when in fact they aren't.
Motul 300V Chrono is a very popular one. Redline for those that want a full Group V oil, but $$
AMSoil, Royal Purple, German Castrol, Mobil 1 - some other decent full synths.
5w30 would probably be the go, especially since you're in NZ, you'll be wanting that cold protection more than us. Unless you the engines see's a lot of track time. I'd be looking at a 0w30/40, or say 5w30 for street duties
the car does mostly drift but a bit of other motorsport stuff as well so a bit of thinking to do
this is the oil we were using
http://www.lubadmin.com/upload/produit/Fic...ang_29/5285.pdf
cheers for your suggestion. we will have to look for a suitable replacement
In Case it hasn't already been mentioned. ANDRA have BANNED E85 as a competition fuel.
Pretty crazy considering they allow 100% ethanol.
I am chasing up the ANDRA fuel guy about it but having no luck.
saw that one coming...
For the SA boys, the Liberty on tapleys hill rd seaton has E85 at the pump, 99.9c :happy:
Thanks for the heads-up Adrian. I've been buying mine from Peter at Scotchers. Any idea what blend the Liberty is 91/E?
Rumour has it that Mobil are starting to sell E85 at their petrol stations.
Unclear if its Australia wide just yet, but there is atleast one in sydney that has started selling it and another (near me) that has just had new tanks put in :)
Taken from Holden's wesite - notice the second sentence. Hopefully widely distributed commercially available E85 is only a matter of time.
Although E85* is not yet widely available in Australia, at Holden, we're working hard to make E85* the everyday fuel for Australian drivers.
In 2010 we'll be launching an E85* flex-fuel vehicle. This vehicle will run on any ethanol blended fuel from E10 all the way to E85*. Plus it'll also be able to run on normal petrol should the need arise.
sorry mate, no idea, ill ask next time I go there, i'd say it be 91 tho, i'm happy, goes good.
not driving it much so wont be keeping too much on hand, 40 litre's at most, the last 44 I got took too long to empty, I recon it went off toward the end, power seemed down and was hard to start!
Looking at the results of this thread has got me pretty excited and pretty bummed out at the same time.
Bummed out because I do not have access to any ethanol in this country (if you have kept up with my current adventure you would understand) .. Excited because I can see all the testing and time I have invested in e85 last year is paying off, there seems to be a big e85 trend going on since I stuck my neck out and tested this stuff in my car, Just search for E85 on google.com.au and you will see how many other forums are linked to us here at SAU.
Looking at the results from Trent @ Status Tuning - URAS has backed up everything that I have found on my initial testing of the fuel. I found a 40 - 50 rwkw increase with my setup but I was using a bigger turbo charger so you cannot compare them with this setup 100% but it does show that when you have a experienced tuner working with this fuel you can see major gains with no other modifcations as long as the fuel system is up to the task then you will have gains all across the board.
It is good to see that you guys are still working on this boost juice, without the support of tuners like Trent and enthusiasts like Joe Joe, Nytsky and Now the all famous Dirtgarage (AKA Twoogle and Mark Jacobson @ Godzilla and a few others like Yavus @ Unigroup Engineering and even JEM) it really puts SAU first in line in Australia for for this remarkable race gas in a pump for only 0.99c a litre.
So yeah, I am sure I do not only speak for myself when this warm fuzzy feeling of E85 love gets its share of internet hits... Its because of tuners and and enthusiasts like us who make it happen.
Keep up the good work! Someone needs to try and and push a complete stock RB25DET to as much power as possible with this fuel... are you up for the mission Trent? :D Can anyone say 400rwkw ?
Theres a user on here pushing 380rwkw (mainline dyno)on a stock engine which he tunes (the car has been running e85 for well over a year now).
Theres no doubt theres 400 in it.
The top end of this car is really something else.....The fuel is very forgiving its awsome stuff.
Edited by RB25DETS2
    • What are we supposed to be seeing in the photo of the steering angle sensor? The outer housing doesn't turn, right? All the action is on the inside. The real test here is whether or not your car has had the steering put back together by a butcher. When the steering is centred (and we're not caring about the wheel too much here, we're talking about the front wheels, parallel, facing front) then you should have an absolutely even number of turns from centre to left lock and centre to right lock. If there is any difference at all then perhaps the thing has been put back together wrongly, either the steering wheel put on one spline (or more!) off, and the alignment bodged to straighteb the wheel, or the opposite where something silly was done underneath and the wheel put back on crooked to compensate. Nut there isn't actually much evidence that you have such a problem anyway. It is something you can easily measure and test for to find out though. My money is still on the HICAS CU not driving the PS solenoid with the proper PWM signal required to lighten the load at lower speed. If it were me, I would be putting either a multimeter or oscilloscope onto the solenoid terminals and taking it for a drive, looking for the voltage to change. The PWM signal is 0v, 12V, 0V, 12v with ...obviously...modulated pulse width. You should see that as an average voltage somewhere between 0V and 12V, and it should vary with speed. An handheld oscilloscope would be the better tool for this, because they are definitely good enough but there's no telling if any cheap shit multimeter that people have lying around are good enough. You can also directly interfere with the solenoid. If you wire up a little voltage divider with variable resistor on it, and hook the PS solenoid direct to 12V through that, you can manually adjust the voltage to the solenoid and you should be able to make it go ligheter and heavier. If you cannot, then the problem is either the solenoid itself dead, or your description of the steering being "tight" (which I have just been assuming you mean "heavy") could be that you have a mechanical problem in the steering and there is heaps of resistance to movement.
    • Little update  I have shimmed the solenoid on the rack today following Keep it Reets video on YouTube. However my steering is still tight. I have this showing on Nisscan, my steering angle sensor was the closest to 0 degrees (I could get it to 0 degrees by small little tweaks, but the angle was way off centre? I can't figure this out for the life of me. I get no faults through Nisscan.
    • The BES920 is like the Toyota Camrys of coffee machines. E61 group head is cool, however the time requirements for home use makes it less desirable. The Toyota Camry coffee machine runs twin boilers and also PID temp control, some say it produces coffees as good as an E61 group head machine.
    • And yes with a full tank it will hit limiter free revving or driving 6B6CDF6E-4094-426D-A9CB-6C553475FE36.mp4
    • One way of putting the fuel surge idea to rest, is that even when in neutral/clutch in or free revving it still has the same issue, it can’t even get to limiter (7800) so to me that says it can’t be g force, I’m not trying to argue I just want to find the f&$king issue 😡
