  • 4 weeks later...
Any major fuel supplier or car company behind E85 can only be a good thing as far as availability goes :D Even if it is....Caltex.
By the way guys, cars do ping on E85, it's just that the sound is not your typical distinctive high pitched rattle that we're used to hearing, rather a very deep thumping noise - far harder to pickup for the untrained ear.
Got my 33 tuned on E85 on Friday with a gt3040 (0.63) rear.
On 98 it (14psi) made 227rwkw and on E85 we wound it up to 18psi and made 252rwkw but gained around 30-35rwkw through the midrange.
Feels more responsive down low but doesn't feel like it hits as hard.
My 555cc injectors are at almost 90% so don't have much more room
I will post up dyno sheet soon.
Get a 0.82 housing.
"Feels more responsive down low but doesn't feel like it hits as hard." This is exactly right, if a turbo is more responsive and has more power/torque down low it wont feel like it hits as hard. Hitting hard is a sharp change in torque. It will be a lot faster with more low down grunt so it just depends on what you prefer.
something's not right.... my 555's are on 92% @ 323rwkw in an RB25 running e85
^^^^ Yes i was looking at yours the other day and realised something is not right with mine. Even the initial 227kw seemed very low as i'm sure it made around 240 last time.
Do you know roughly how much extra timing you were able to run? Also did you keep pulling fuel out until it started losing power?
i think the reason for the lack of power aswell as the high injector duty is a very restrictive exhaust side. change to a .82 or 1.06 housing and make sure your exhaust isnt too restrictive
yep, my .63 rear (or near enough, probably a little small, OP6) makes 290rwkw on E85 (740cc injectors)
Hamish, your rear housing is a smiliar sized judging on the boost curve, and it makes oodles or power as well.
don't know the exact specs of the gt3040 though...
Afternoon all,
I've been following this topic and looking forward to seeing this fuel at the pump in QLD, whenever that may be....... I came across this article today about biofuels and thought I'd share it with all.
Hey Guiltoy, how's it feel to be 2years ahead of the US Military?
http://www.smartplanet.com/business/blog/s...-biofuels/6274/
"A U.S. Navy-owned F/A-18 Super Hornet is the first supersonic jet with afterburners to fly on a biofuels blend."
Do you think i should drop the exhaust next time?
I still dont get the duty cycle being so high (hit 92% yesterday) with 550 injectors and i presume a good pump.
if you are getting any sort of restriction i would always drop the exhaust and do a run... it costs nothing and helps problem solve at worst
The absolute reality of the situation is that any major retail fuel supplier will dick around with the percentage of ethanol in the mix. I don't even think it'll be called E85 at the pump. Probably 'high ethanol unleaded' or similar.
Whether an argument for a seasonal mix exists in Australia (I don't believe it does), the fact of the matter is that fuel companies will use the cost of ethanol at any given time and their ability to vary the ethanol content to leverage the wholesale cost of unleaded petrol.
In short, the mix will almost certainly change between 70% to 85% without warning and you won't know when or where.
= danger.
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
    • BTW I measured the jack I have, it is 70mm at the saddle but you only have about 700 until it returns to 150mm high at the cylinder so it is good but no magic bullet.
    • My experience with Rising Sun Exports Before agreeing to the sale I tried to do as much research as I could (obviously), his Facebook reviews are 98% and he goes Live at least once or twice a week. I contacted 2 people in the UK who had used him for their imports, both had positive feedback. His explanation and talk through of the import process was thorough, answering any query no matter how stupid it was. It felt as soon as the money was sent, communication dropped off. I asked for shipping updates every 2 weeks or so, not wanting to pester him, he never had any updates. I wasn't informed the car had been dropped off at the port, I only found out by his Facebook story. I asked for the photos taken at the port, knowing he would need some for insurance purposes. I received a few 5 second clips and that's it. When asked again, he said his staff had them. Weeks later I asked again, he tells me he doesn't have any, but does have 50 photos from the original advert. I never received them. I eventually got the documents sent via WhatsApp after I mentioned the port was requesting them. I purchased a CarVX report, to find out the vehicle is a Grade R with recorded accident damage, first recorded in 2017 when it was first auctioned. He never told me the grade, then again I didn't ask. His response was "Grade R means nothing, it wasn't chassis damage". Still, I would have liked to have been informed about it. Jon prides himself on being open and honest when it comes to inspecting cars, it's his main job doing so at the auctions for customers. When the vehicle arrived in the UK I noticed a few little cosmetic issues. It's a 21 year old car so it wasn't going to be mint condition. The side skirts are cracked on each corner and the sealant is failing. The front grill on the bonnet/hood isn't secured very well, mounting studs are missing. Both minor things, but again, it would have been nice to be told. During a Facebook Live walk around video of the vehicle, he mentioned it has a front Whiteline anti roll bar/sway bar. While on the inspection ramp, I noticed the stock item has been installed. When first questioned, his response was "the ARB? Switched? Since when, it never had them". Since sending video and photo evidence I've not received a response. I'm probably being over critical of the overall condition of an old car, but all I wanted was honesty (which he claims to have). I'm aware I wasn't his only customer, he's busy doing XYZ but other reviews praise him for great communication with regular updates and photos, I felt I didn't receive the same treatment.
    • I was able to get some underside photos while the car was on the ramp The suspension is all Altezza/IS200/IS300 so getting part's will hopefully be less of a headache
    • Welcome to my 2004 Toyota Mark ii IR-V Fortuna (series 2) With a 1JZ-GTE powerplant under the bonnet (hood) it'll give me plenty of scope for power upgrades. For those who aren't familiar with imports, the 1JZ-GTE is a 2.5L 6 cylinder VVTi engine with a single turbocharger. This has the factory R154 5 speed gearbox, along with a aftermarket 2 way LSD differential (brand unknown). Under the arches are a set of CST Zero 1 alloys, 18x9 +30 225/40 up front and 18x9.5 +15 265/35 on the rear. The car was quite low in Japan and there's evidence of the wheels catching the rolled arches/fenders. The tyre's aren't great so I'm in two minds whether to replace both or just the tyres and put up with the wider wheels on the rear. The car still uses stock brakes with the addition of some braided hoses. The exterior is stock with the exception of a BN Sports front bumper and a replacement Fortuna grill  Moving to the interior, the steering wheel has been replaced with a dished MOMO steering wheel (which will get swapped for my Momo Tuner for the time being) Defi Link Gauges are mounted above the climate controls and on the A pillar, the Oil Temp,Oil Pressure,Water Temp and Boost gauges should help with spirited and track driving  The stock seats have been replaced with some retrimmed Recaro bucket seats. Being a larger build these are a little snug, unfortunately the orange isn't for me so I'll look into replacing these down the line. Other modifications include a twin plate clutch, Blitz intercooler, Evolve alloy radiator, a stainless exhaust with decat, HKS EVC-S boost controller and coil overs
