  • 4 weeks later...
Any major fuel supplier or car company behind E85 can only be a good thing as far as availability goes :D Even if it is....Caltex.
By the way guys, cars do ping on E85, it's just that the sound is not your typical distinctive high pitched rattle that we're used to hearing, rather a very deep thumping noise - far harder to pickup for the untrained ear.
Got my 33 tuned on E85 on Friday with a gt3040 (0.63) rear.
On 98 it (14psi) made 227rwkw and on E85 we wound it up to 18psi and made 252rwkw but gained around 30-35rwkw through the midrange.
Feels more responsive down low but doesn't feel like it hits as hard.
My 555cc injectors are at almost 90% so don't have much more room
I will post up dyno sheet soon.
Get a 0.82 housing.
"Feels more responsive down low but doesn't feel like it hits as hard." This is exactly right, if a turbo is more responsive and has more power/torque down low it wont feel like it hits as hard. Hitting hard is a sharp change in torque. It will be a lot faster with more low down grunt so it just depends on what you prefer.
something's not right.... my 555's are on 92% @ 323rwkw in an RB25 running e85
^^^^ Yes i was looking at yours the other day and realised something is not right with mine. Even the initial 227kw seemed very low as i'm sure it made around 240 last time.
Do you know roughly how much extra timing you were able to run? Also did you keep pulling fuel out until it started losing power?
i think the reason for the lack of power aswell as the high injector duty is a very restrictive exhaust side. change to a .82 or 1.06 housing and make sure your exhaust isnt too restrictive
yep, my .63 rear (or near enough, probably a little small, OP6) makes 290rwkw on E85 (740cc injectors)
Hamish, your rear housing is a smiliar sized judging on the boost curve, and it makes oodles or power as well.
don't know the exact specs of the gt3040 though...
Afternoon all,
I've been following this topic and looking forward to seeing this fuel at the pump in QLD, whenever that may be....... I came across this article today about biofuels and thought I'd share it with all.
Hey Guiltoy, how's it feel to be 2years ahead of the US Military?
http://www.smartplanet.com/business/blog/s...-biofuels/6274/
"A U.S. Navy-owned F/A-18 Super Hornet is the first supersonic jet with afterburners to fly on a biofuels blend."
Do you think i should drop the exhaust next time?
I still dont get the duty cycle being so high (hit 92% yesterday) with 550 injectors and i presume a good pump.
if you are getting any sort of restriction i would always drop the exhaust and do a run... it costs nothing and helps problem solve at worst
The absolute reality of the situation is that any major retail fuel supplier will dick around with the percentage of ethanol in the mix. I don't even think it'll be called E85 at the pump. Probably 'high ethanol unleaded' or similar.
Whether an argument for a seasonal mix exists in Australia (I don't believe it does), the fact of the matter is that fuel companies will use the cost of ethanol at any given time and their ability to vary the ethanol content to leverage the wholesale cost of unleaded petrol.
In short, the mix will almost certainly change between 70% to 85% without warning and you won't know when or where.
= danger.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
