what the wideband think of it?
and talk about quite cheaper than United/Fueltown
Flat 12 afr same as Southland. For some reason it feels like it has more poke if thats possible. Give it a try...
If you go to the Springvale road Caltex, pump 7 takes forever, use pump 8. :banana:
Sounds too small to me, If you are maxing your injectors now it would be a good idea to get at least 50% larger. You will require 20 - 30% more flow straight away.
I run 14mm 610cc Deka's with no problem on a VQ25det but on a 3L you may want more fuel than that. 044 should be fine.
Bang on mate.
My 570cc Siemens are maxing at 337 rwkw in the RB25/30 + GT3076R 20psi - single 044
Right now, I'm in no rush to fill up Ethanol but I'm keen to get the car ready on the next service.
Should I go 750cc or 870cc ? Same price too.
Would you expect with the 870's I might get rough idle/ bad economy.
What about driveability on a daily basis... The car right now is very smooth and linear.
Putting aside E85, would you expect the 3076 hasn't got much left and the 750's may be more suitable ?
Tuning is no issue with the Haltech S2000.
Sorry to drop so much at once.
Cheers.
S2000, just what my tuner recommended for mine once i'm bored with the Emanage Ultimate. :P
Personally I would go the 870's or larger if you plan to run E85 in the future. You're already doing pretty well with the 3076, is that with the .82 rear?
Yes, and stock manifold.
Also put the large can actuator on it. Holds 20psi flat line easy.
My mech says theres still more in it, maybe another 4 or so.
cheers.
Just got back from the caltex in preston and they have no idea of what E85 is also!! Does anyone know when its supposed to come in all those 10 pumps that they have said it should be coming soon in...
Definetly switching to E85 if it comes there soon, 5 mins from home!! :(
Just got back from Caltex, its definitely e85 and costs only 92.7c per litre.
Just to put a spanner in it, now on my third tank and it has richened considerably. Getting down to 10.5:1 now so looks like it is e70. One benefit is I got an extra 50k's to the last tank.
Im booked in for another touch up on a different dyno, I will have to make an e70 map now.
The price is fluctuating a bit, I asked the Caltex attendant and they said they are selling it at 20c under unleaded. I asked why as it has bugger all crude in it... Surely it shouldnt change price as drastically as 91. Perhaps we have had it too good at Southland.
I have tried most of the east side servo's Caltex listed, only Springvale and Clayton have it so far, the rest will be installed before the end of the year.
LOL at the "Run ID" Couldn't get it to ping????
Nice results, i can't wait for my caltex to bring the felx fuel out!
I spote to the tool at the counter yesterday at the servo and he knew f**k all about it and said it won't be in till next year :D
This is one of the 2 catlex's in canberra claiming to have it by the end of oct
Latest tune, Caltex e70 FTW!
Stage 1 Sierra ATP highflow on a VQ25det. :geek:
So how come they changed from 85 to 70 just randomly I thought it was going to be switched at like hotter and colder months. What are you going to do now when it goes to 85 if your on the 70 tune?
    • Yeah and hence my ghetto way of slamming the brakes, get the ABS to cycle, rebleed seems to be a sensible workaround.
    • Hey! Happy to help. Nothing inherently wrong with the adapter, it's more so with Brett Collins himself. He gave me a lot of incorrect information when I was in contact with him and was extremely rude when I challenged him. He stated I could not use any aftermarket twin plate clutches except for his own, not to use the dush shield, bla bla bla and it was all BS.  Collins stated to cut roughly 14mm's off the housing, I took off 15mm to make room for the dust shield. I would confirm with whatever adapter manufacturer you're using.
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
