what the wideband think of it?
and talk about quite cheaper than United/Fueltown
Flat 12 afr same as Southland. For some reason it feels like it has more poke if thats possible. Give it a try...
If you go to the Springvale road Caltex, pump 7 takes forever, use pump 8. :banana:
Sounds too small to me, If you are maxing your injectors now it would be a good idea to get at least 50% larger. You will require 20 - 30% more flow straight away.
I run 14mm 610cc Deka's with no problem on a VQ25det but on a 3L you may want more fuel than that. 044 should be fine.
Bang on mate.
My 570cc Siemens are maxing at 337 rwkw in the RB25/30 + GT3076R 20psi - single 044
Right now, I'm in no rush to fill up Ethanol but I'm keen to get the car ready on the next service.
Should I go 750cc or 870cc ? Same price too.
Would you expect with the 870's I might get rough idle/ bad economy.
What about driveability on a daily basis... The car right now is very smooth and linear.
Putting aside E85, would you expect the 3076 hasn't got much left and the 750's may be more suitable ?
Tuning is no issue with the Haltech S2000.
Sorry to drop so much at once.
Cheers.
S2000, just what my tuner recommended for mine once i'm bored with the Emanage Ultimate. :P
Personally I would go the 870's or larger if you plan to run E85 in the future. You're already doing pretty well with the 3076, is that with the .82 rear?
Yes, and stock manifold.
Also put the large can actuator on it. Holds 20psi flat line easy.
My mech says theres still more in it, maybe another 4 or so.
cheers.
Just got back from the caltex in preston and they have no idea of what E85 is also!! Does anyone know when its supposed to come in all those 10 pumps that they have said it should be coming soon in...
Definetly switching to E85 if it comes there soon, 5 mins from home!! :(
Just got back from Caltex, its definitely e85 and costs only 92.7c per litre.
Just to put a spanner in it, now on my third tank and it has richened considerably. Getting down to 10.5:1 now so looks like it is e70. One benefit is I got an extra 50k's to the last tank.
Im booked in for another touch up on a different dyno, I will have to make an e70 map now.
The price is fluctuating a bit, I asked the Caltex attendant and they said they are selling it at 20c under unleaded. I asked why as it has bugger all crude in it... Surely it shouldnt change price as drastically as 91. Perhaps we have had it too good at Southland.
I have tried most of the east side servo's Caltex listed, only Springvale and Clayton have it so far, the rest will be installed before the end of the year.
LOL at the "Run ID" Couldn't get it to ping????
Nice results, i can't wait for my caltex to bring the felx fuel out!
I spote to the tool at the counter yesterday at the servo and he knew f**k all about it and said it won't be in till next year :D
This is one of the 2 catlex's in canberra claiming to have it by the end of oct
Latest tune, Caltex e70 FTW!
Stage 1 Sierra ATP highflow on a VQ25det. :geek:
So how come they changed from 85 to 70 just randomly I thought it was going to be switched at like hotter and colder months. What are you going to do now when it goes to 85 if your on the 70 tune?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
