I'm very much limited to what NIStune can do.
Other than the fact that I would have had a bit more stuffing around to sort nistune on a 33, this is why I spent the bigger dollarz and went with the ViPEC :)
OK so since it looks like nobody want to buy my rims lol, I'll probably get myself new a new CAT of some description, and a wideband from wbo2 in the coming months....
and some ku36's, coz these Maxxis tyres SUCK with power.
sorry if this has been covered earlier, my wideband doesnt read in lambda so im stuck with the gasoline calibrated AFR's.
what ive read is you divide your GAS AFR by 1.5 to get your actual AFR on E85.
it looks like the AFR's on your GAS calibrated AFR dont change too much, ive ripped a table from: http://www.e85forum.com/ntopic777.html&amp...721aef0b42b578a
Idle/Cruise = 14.7 - 15.2
Light Load = 12.5 - 13.2
Pre-WOT load = 11.5
WOT = 11:1 - 10.5
these figures are for gasoline calibrated AFR's.
does this sound right to the pro's?
update on my E-Flex adventures.
Car feels AMAZING to drive, more torquey, smoother throughout the entire rev range.
290rwkw with siemens deka 550cc injectors, walbro pump. still more left in the injectors, and pump seems to be keeping up just fine.
i ran a walbro the whole time i was on E85, 740cc injectors - never any issues, prob about 18months straight of exclusive E85 use - bout the same power as well
Your opinion is invalid as you have shown mental instability when you sold that absolutely amazing R34 of yours. Shame on you.
lol :blink:
Oh I didnt realise that result was on E85! Did you have a tune on 98 as well?
He only ever got his 98 tune results once I believe, and it was with a really restrictive intake so it only made 266rwkw when the piping was killing airflow.
This tune was on E-something....like E70 or thereabouts
Here's a quick excel of my pre and post caltex e flex fuel :blush:
NOTE!!! the Caltex E-Flex was actually run with LESS boost
PULP 98 spiked up to 21psi then dropped to 15 and held
Caltex E-Flex spiked to 19psi then dropped to just under 14psi by redline (where peak power was made)
I used the formula ((Speed/28)*1000) for the revs. Not exact but very close
almost 50rwkw gain through the midrange and this is only e70 at the moment...
giggity!
Yeah Pat your results make me cry. LESS boost, and HUGE gains in midrange. Fark I gotta get up early to fix my cooler piping tomorrow, not driving my car hurts. Can't wait to make the switch as well, just gotta get a bloody wideband :blush:
fark.. you guys are still going with this :thumbsup:
I been in Abu Dhabi in UAE tuning, fuel here costs 50c a litre for 98 =) and money is never a problem for guys wanting to build cars...
how different is the Caltex stuff to the United stuff? With e85 i never had any starting issues, only difference was a extra 4 cranks of the engine and that was it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
    • Run some injector cleaner through it I had a similar issue that plagued me for months, even tried replacing the cat. If one or more injectors are blocked up the ecu sees ping so pulls timing and makes the tune rich overall, you'll see black smoke coming out of the exhaust and like me assume it's running rich but it could only be one or two cylinders  $10 bottle of injector cleaner and the next time I hit boost it pumped out a huge plume of black smoke, cleared the blockage and then ran great, if that's not the issue it's only a cheap thing to try haha
