fark.. you guys are still going with this :)
I been in Abu Dhabi in UAE tuning, fuel here costs 50c a litre for 98 =) and money is never a problem for guys wanting to build cars...
how different is the Caltex stuff to the United stuff? With e85 i never had any starting issues, only difference was a extra 4 cranks of the engine and that was it.
It's stickied mate, thread'll nevar die!!!
I never tried the united stuff so i can't really comment on it, appart from saying it's f**king awesome fuel :thumbsup:
This was the wideband im thinking about getting, what do you think for the price?
http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...e=STRK:MEWAX:IT
Looks like a nice quality unit.
You're not interested in logging though? I didn't see anywhere saying it had 0-5v analog out...
I agree, does it have a programmable output for the ecu? I find logging with the EMU the best way to track afr's.
I have the LC-1 kit, its been in for nearly a year with no issue. I know a few guys have had problems with these in the past but for $200 it has been a good buy. Perhaps running E85 prolongs the sensor life?
http://www.innovatemotorsports.com/xcart/p...=262&page=1
fark.. you guys are still going with this :P
I have used all three ethanol brands available from the pump, There wasnt that much between them but the Caltex E70 definitely starts much better in my car and feels stronger.
Im wondering if there is a happy mixture, with enough petrol to help burn the mixture completely during the downward stroke, rather than pump it out the exhaust...
interesting write up. anyone else tested the ethanol content of united's stuff?
btw the reason for caltex's higher price is they're simply selling it at 20c/L less than ulp regardless of the mix. so it goes up and down with ulp by the same amount, even tho its only 15-30% ulp
Interesting.. I was going to come home soon and get back on the E85 but now something else has come up and I wont be home for quite a while.. *sigh*
nice results... its good shit
Ive only ever used the United fuel. No complaints here.
As for cold start it would start every time on the 3rd crank.
Ive noticed mine starts MUCH faster in the warmer weather we have had lately.
Starts just as fast as my commodore (which is straight away)
I have more of an issue as the fly-by-wire throttle doesn't allow me to give it a squirt of pedal to start, coupled with the Emanage not being great with cranking enrichment... I really appreciate the e70 any morning its under 15 degrees.
Not real impressed with Caltex's reason to swing between E70 and E85. Might be OK for those commodores but not for us with a single tune for 85% Ethanol.!!!
They are just following the US lead they have been told to follow. Its a GM global push.
Nothing 5 litres of petrol wont fix, the main hassle is you wont know when they are changing the mix. Remember, none of us are supposed to be running Caltex bio Eflex.
How will 5 litre of petrol fix the issue when the ethanol content is already less then it should/needs to be?
What does it need to be? Do you have an e85 tune from one of the other suppliers?
If you are running Caltex you will have an e70 tune which will run fine when and if they switch over to e85 by just throwing a few litres of 98 in... Good idea to have a wideband if you are playing with the Caltex brew.
It will be tuned on the United E85 so I would assume that would be 85%. But I now see what your saying. If you tune it on the "E70" and you get "E85" a few litres of normal fuel would make it a bit more even. But are you going to bust out the lab in the fuel station to work out what it is everytime you need a tank of juice?
If you call a simple wideband sensor and gauge a "lab" lol, United e85 seems to be e90-95 from my experience, the Southland Manildra blend is closer to the mark. I would suggest tuning for the fuel you plan to use.
i have mine tuned on E85 from united. was already mega fat on the dyno due to a problem we had on the day, but around the 0.76 lambda mark.
today at winton, with the caltex E70 in it, used mix trim to take out 8% of fuel and it was still at 0.71 on the meter (microtech meter only reads as low as 0.71).
caltex mix is meant to be from march to mid november.
im going to give it a week, then get a litre from caltex and do another test to see if the tanks have been filled with E85 yet.
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
