Bosch 1000's, you should be able to get them for around the same price, why would you go for anything else these days for less than 500kw.
Cheers mate, bosch 1000's are even cheaper than rochester 1000's. Only problem is i'll need to change the fuel rail to fit either, i found a set that will fit into the stock rail made by deatschwerks but they are a good $115 a piece. Weighing up whether its worth going for Bosch 1000's and a new rail or go the deatschswerks. Personally i think if i'm going to up the ante later on down the track it'd be worthwhile going for a new rail, eh?
Damn!
What is the current E content of the United stuff? How does it compare to E-flex?
I have no idea, as long as the wideband shows less than 12:1 im happy, if it ever got leaner than that I would be adding a little 98 and getting another tune but I haven't seen much variation on the wideband in 3 years to worry about it at all.
^^tis e85
There are 4 United servo's in NSW now, hopefully more will follow as they are pumping the Melbourne rollout heavily. Dont look if you don't want to get upset. lol.
http://www.unitedpet...cator/fuels/E85
there everywhere here now, cant believe those 2 shell servos just before the Westgate bridge are now Uniteds..
When you have waited 3 years for a local servo like I have, its hard to not be excited. Sorry, I will try to contain myself. :)
If its any consolation it took me 5 minutes to start my car today, I almost threw in the towel and got the aerostart. Gotta get the tune done, these cold starts are killing me. (or at least have the laptop out for a fiddle)
About 5 kw
Haha I'd be excited too.... But my result on E70 was crazy enough... E85 wouldn't make any more on mine i reckon as its maxed the exhaust and turbo combo.... So its probably one of those results that would vary, but at the end of the day if it's 5kw over 300 then it's bugger all ;)
Perhaps, but those 5 here and 5 there can add up to a lot of extra power once all the restrictions are taken care of.
It would give you a gain, mine was well maxed and I squeezed another 6 out of it. Mainly changed as its local to me.
Unfortunately Caltex seem to have stalled with their e85 rollout, much to Holden's disgust i'm sure. They got burned hard on the contract to supply it when the ethanol dried up last year, so I understand their unwillingness to install more pumps until demand has risen. (or until their waste ethanol plant is up and running) United on the other hand are set on cornering the market by the looks of it, a good position to be in as petrol gets more expensive.
Anyone care to guess what will happen to petrol prices in the carbon trading economy? The government would be stupid to stifle e85's take up by taxing their greenest fuel option to date but who knows...
Nothing would suprise me at the moment.... None of the governments seam to give two shits about ethanol fuel, especially over here where it's still illegal because they haven't got around to ammending the old laws.
STFU eastern pricks and your ethanol!
yeah, the united on Davey street has it too though I dare say Baxter has newer/cleaner tanks...
So what sort of mileage did you get on your PI trip last week..did you have to use jerrys as well.??
Only got about 200kms out of my first tank...bit of a worry..
Ha! I've chucked a couple of 20L Jerry's in
My car to do to and from work... So far fuel economy seems to be a fail... Am gunna fill up on Sunday and do a commute report ;)
I'd just be very satisfied as I've ranted before, if modded vehicles are locked in tune to E70-85, were left alone by the EPA and cops, on the basis they are a very proven pollution emissions reducer. It seems too logical and simple for the numpties in power, if we have modded to pollute less, leave us alone on the roads from than angle. Meanwhile an E10 unserviced standard worn out hack spewing smoke from engine wear, on barely treaded tyres is generally left alone.
Edited by DR 32R
    • I'm an idiot, my intercooler is rated for 1000hp. I had clicked on the wrong product. Knowing the delta P would be nice, but I'm doubtful I'll do it. Now as for an EMAP, that would be great and I'll get around to it eventually but from my findings in my last post, I'm considering a turbo swap now.
    • You sir, big win tonight. Precision never supplied compressor maps in the past and Idk when they started, but it seems they only offer for a few of the older gen2's which is exactly what I have. I punched in some numbers and seem to have gone with the wrong turbo. 600-700whp isn't in the most efficient area and is close to the choke line. 800whp is well off the map. Punching the numbers into a 68mm gen2 turbo map is bang on in the center. Here I was thinking going smaller would shift the power band down, but in reality it would just make it so much worst due to my rev limit. I would have never thought.
    • Increasing overlap will bring the torque down earlier (and make your idle sound sick lol). Worth a shot (if you dyno time) to experience a bit (providing you are confident your valves won't kiss your pistons). Is to just take off 5 degrees across the boosted area of the map, and then retard the exhaust cam let's say, 3 degrees at a time and then overlay all the runs with VCT on all the way and VCT off as soon as you make positive pressure. Ideally you would have a total of 6x overlays to looks at 0 exhaust & VCT off once manifold pressure is +ve 0 exhaust & VCT on all the way -5 exhaust & VCT off once manifold pressure is +ve -5 exhaust & VCT on all the way -10 exhaust & VCT off once manifold pressure is +ve -10 exhaust & VCT on all the way Just leave your O2 wideband closed loop on for all of the boost area & RPM, and hopefully there isn't too much fuel correction needed and the Haltech is fast enough to compensate (I do this, then apply the correction to the main table). Getting that overlay data should give you a good indication of what to aim for.
    • So, my main limitation here is that the car does not have an oil pressure sensor by default, just a switch. As part of my tune I bought an oil pressure sensor upgrade so I now have access to oil pressure levels and logging rather than just the boolean behaviour of the switch but this means I need to use the tuning app to display this value. So, this rules out using any other app on the iPad. The app will also flash when pressure drops which is a nice feature. I have replaced the centre screen with an Android one, which is awesome for Android Auto, but I think it might be too far away and out of my line of sight. I might add some gauges to it this weekend and just see. I guess if its just temp and oil pressure I can make them massive! 🤣
    • This is what the look like normally. Except we only got the 2 doors locally
