Bosch 1000's, you should be able to get them for around the same price, why would you go for anything else these days for less than 500kw.
Cheers mate, bosch 1000's are even cheaper than rochester 1000's. Only problem is i'll need to change the fuel rail to fit either, i found a set that will fit into the stock rail made by deatschwerks but they are a good $115 a piece. Weighing up whether its worth going for Bosch 1000's and a new rail or go the deatschswerks. Personally i think if i'm going to up the ante later on down the track it'd be worthwhile going for a new rail, eh?
Damn!
What is the current E content of the United stuff? How does it compare to E-flex?
I have no idea, as long as the wideband shows less than 12:1 im happy, if it ever got leaner than that I would be adding a little 98 and getting another tune but I haven't seen much variation on the wideband in 3 years to worry about it at all.
^^tis e85
There are 4 United servo's in NSW now, hopefully more will follow as they are pumping the Melbourne rollout heavily. Dont look if you don't want to get upset. lol.
http://www.unitedpet...cator/fuels/E85
there everywhere here now, cant believe those 2 shell servos just before the Westgate bridge are now Uniteds..
When you have waited 3 years for a local servo like I have, its hard to not be excited. Sorry, I will try to contain myself. :)
If its any consolation it took me 5 minutes to start my car today, I almost threw in the towel and got the aerostart. Gotta get the tune done, these cold starts are killing me. (or at least have the laptop out for a fiddle)
About 5 kw
Haha I'd be excited too.... But my result on E70 was crazy enough... E85 wouldn't make any more on mine i reckon as its maxed the exhaust and turbo combo.... So its probably one of those results that would vary, but at the end of the day if it's 5kw over 300 then it's bugger all ;)
Perhaps, but those 5 here and 5 there can add up to a lot of extra power once all the restrictions are taken care of.
It would give you a gain, mine was well maxed and I squeezed another 6 out of it. Mainly changed as its local to me.
Unfortunately Caltex seem to have stalled with their e85 rollout, much to Holden's disgust i'm sure. They got burned hard on the contract to supply it when the ethanol dried up last year, so I understand their unwillingness to install more pumps until demand has risen. (or until their waste ethanol plant is up and running) United on the other hand are set on cornering the market by the looks of it, a good position to be in as petrol gets more expensive.
Anyone care to guess what will happen to petrol prices in the carbon trading economy? The government would be stupid to stifle e85's take up by taxing their greenest fuel option to date but who knows...
Nothing would suprise me at the moment.... None of the governments seam to give two shits about ethanol fuel, especially over here where it's still illegal because they haven't got around to ammending the old laws.
STFU eastern pricks and your ethanol!
yeah, the united on Davey street has it too though I dare say Baxter has newer/cleaner tanks...
So what sort of mileage did you get on your PI trip last week..did you have to use jerrys as well.??
Only got about 200kms out of my first tank...bit of a worry..
Ha! I've chucked a couple of 20L Jerry's in
My car to do to and from work... So far fuel economy seems to be a fail... Am gunna fill up on Sunday and do a commute report ;)
I'd just be very satisfied as I've ranted before, if modded vehicles are locked in tune to E70-85, were left alone by the EPA and cops, on the basis they are a very proven pollution emissions reducer. It seems too logical and simple for the numpties in power, if we have modded to pollute less, leave us alone on the roads from than angle. Meanwhile an E10 unserviced standard worn out hack spewing smoke from engine wear, on barely treaded tyres is generally left alone.
Edited by DR 32R
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
