So I've recently replaced my old HKS 2530'S with the GARRETT 2860'S-5. I was instantly impressed with the low down power. I'm still trying to convert the speed into RPM to get a direct comparison. Because the shop that did the power run with the garrett's was a V8 place they didnt realise the RPM limit, getting off it at around 7,000rpm in 4th opposed to 8,200rpm so the run was never complete.
Now, they were different dyno's but I've had my car on both previously making nearly the same power. But needless to say these GARRETT turbo's are good bang for buck. On the garrett run we had major issues with wheel spin, seen in the dyno also.
HKS 2530'S made 21PSI at 5300
GARRETT 2860'S made 20PSI at 4,300
Edited by monga
https://www.sau.com.au/forums/topic/239481-garrett-2860-5-v-hks-2530s/
Can you get it on the same dyno? Just from the corrections you can see a number of differences
IT Temp - 52degree vs 23 (which will affect outright power signifigantly)
Shoot6F vs Shoot6
And the list goes on :happy:
That first graph though, the 2530's come on pretty late :banana:
Have you changed anything other than the turbos??? Like cam gears, cams, tune etc?
I ask as the 2530's arent making 320rwkw till 5800rpm so there was definately something 'up' with the 2530 run. They should be markedly more responsive than that.
Change nothing, just took those turbo's off then replaced them with new ones. The two dyno's make very similar power, as I've compared in the past. Regardless its a tuning tool and turbo's worth just over 2k are good value.
What mods are done to your car?
And it might be good to get another dyno done showing RPM. Might be worth it since you have gone to this length of trouble.
IMO the biggest difference between hks 2530 and the -5 is that HKS changes the inside of their housing which allows more airm gives slower spool up time but more top end if that makes sense.
R32 GTR's do 28.5 km/h per 1000rpm in fourth.
Oh there is no dbout price vs effectiveness the garretts win hands down, totally agree there.
Im just @ a loss as to your 2530 response (or lack there of), its very sub-standard where they should be much closer to the -5's response :banana:
240rwkw @ 5000rpm is no good for the 2530!
Do you have cam gears?
Maybe the 2530's like a different setting to the -5's perhaps? (just thinking what could be the cause)
No cam gears dude.
I think the 2530's are reasonable, here is Jonn's dyno with the 2.8 stroker with the same sort of power line locally here also.
I think the 2530's would handle more boost and rpm, the 2860's feel awesome for the track ect.
http://www.skylinesaustralia.com/forums/in...st&id=15204
Thats a 2530 graph, and you can see its very similar to your -5's graph give or take a bit which is fair enough.
It was m&m's setup from a couple years ago.
http://www.skylinesaustralia.com/forums/in...t&p=1797201
Its all interesting :(
You've got big cams too dont ya? (was looking @ ur post in RB26 dyno thread)
Cam's are reasonable dude, depends on tune also I guess if we increased the timing the power band could change. I'll hunt around but I've got my garagesauras power run around here somewere and its got bulk timing tuned to 102RON and brings them on much earlier.
generally do the 2530s run out of puff or blow first?
I was thinking 350kw should be achievable from my car with 2530s without too much lag
it was laggy before with the 2530s, exhaust and boost controller, but i was thinking porting, and cam gears should be enough to help avoid this?
I think the 2860's will run out of puff before the 2530's, which technically will make more outright and topend power. 350kw is achievable wth both.
Depends what you call lag, if your happy with power around 4,500-5,000rpm you should be fine.
Few graphs from here on the West.
Great graph...would have loved to see -7's and -9's plotted as well.
2530's and -5's improve response with a good set of Cams.
GT-RS can only improve with a larger displacement.
Interesting graph comparo Brockaz, some setups have given interesting results!
Actually Brockaz - do you have Gav's graph with the new turbos on it to stick into that?
It would be something to drool over :banana:
im about to install a set of -5's on my gtr in the next week or so, waiting for them to come in as they are out of stock.. will post my graph as soon as its dynoed.. our goal is the low to mid 300kw at all 4s mark
from what i have heard, definately great bank for buck with the garretts
I only have one of his preliminary tunes.
I'll see if I can get a copy of his latest graph, which shows the -5's with roughly the same top end as the GT-RS's but with the massive midrange.
I can probably get a copy of a set of GT-SS's running abour 460hp to compare as well, so I've kept all the data and will add to it when I get the chance.
Oh, and the 2.8L of John's with the 2530's is running roughly 20psi.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
    • Very good news...I contacted Racebox about it last night. My car is a 2016 so remains to be seen if it is compatible, requires a TCU swap, or is impossible.
