Car:
89 R32 GTR
Problem:
Misfire at idle and when i try to hold it at a certain amount of revs (e.g) 1500, 2000, 2700, etc etc., it idles at 1100-1200 rpm, and if i rev it to about 3000rpm and let my foot of it tries to stall on me. (1 out of every 3 times)
it revs up fine and boosts ok. but wont sit at any certain amount of revs.
tried:
coilpacks
plugs
cleaned/checked AFM
Replace coilpack wiring harness.
replaced all intercooler clamps etc.
any help would be great.
https://www.sau.com.au/forums/topic/239605-urgent-help-needed/
  • Replies 42
where are the AFM's... likely too close to the comp housing.
Why you running all that stock gear with a T04Z anyhow? (and dont say 'running in' the motor)
i have 700cc injectors to go in, and plan to get a power fc, but i wont spend the coin on a power fc incase i need the cash to fix whats casuing the misfire.
so just want to get that sorted first.
don't think the afm's are too close if they were any further from the turbo they would be outside of the car. i can barely fit a thin hks filter between the afm's and the washer bottle and passenger headlight.
i just went and checked for error codes again and got: #21 (ignition signal system) my manual says: ignition signal is not generated continuously even though crank angle sensor is entered (dissconection between power transistor and control unit).
i check voltages to the coil packs and igniter but how do i check the sginal wire?
Check that the part where the CAS goes into isn't chewed out. It allows the CAS to flop around, and jumps timing up and down and causes mis fires mainly when attempting to hold revs constant.
fits snug in there..plus its held in by the 3 bolts
no error codes anymore... #55 (all good).
the misfire became less when i fixed an injector plug up (was still missing). after driving it a bit the miss gets worse and it starts to idle at 1500 rpm again. and goes up and down from 1400-1500.
given up.
given up.
when cold it idles at 1100rpm and doesn't miss... then about 30-40 seconds later it starts...the hotter it gets th worse it gets..
(sounds like dodgey coil-packs but i've changed them and they wouldn't make the revs rise to 1500rpm at idle)
anymore ideas?
STILL HAVE A MISSFIRE!!!
I have now done:
new plugs (3 sets)
coilpacks (3 sets)
new coilpack wiring harness
New injectors
New Power FC
New Z32 AFM's
Crank angle sensor
just check to make sure you have no vacum leaks. its along shot but start from there. correct me if i'm wrong but didn't you have a problem a couple of weeks ago with it not starting?
i have checked for vaccume leaks and also replaced all hose clamps... i wouldn't have thought that would cause it to missfire...
yeah i had trouble with it starting... had no power to coilpacks..(all sorted)
To save reading previous posts... this is where i'm at.
I need some more ideas please...
Problem: Missfire
What happends: runs fine for about 5-6minutes (only when started from dead cold, once its a little warm it missfires every start), then starts to missfire, if you give it a few revs and let the throttle off it dies for a split second and then the revs go up to 2000rpm (at idle) then slowly come back down to 1200rpm. (missfire the whole time)
replaced:
Igniter pack
Coilpacks
Plugs
Fuel regulator
Injectors
AFM
Replaced all hose clamps
checked all possible air leaks.
new power fc
new o2 sensors
New temp sensors
New ignition wiring harness.
the engine is fresh and has had all new gaskets fitted etc.
Any more help with this would be great. I'n my head i feel its a vaccume leak issue still... what else would cause the problems mentioned?
Edited by BNR 032
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
