i culd even turbo the LS1 and get close to 500hp atw if i got a big enough kit... gas motorsports got sumthin similar to that...
and if i got bigger injectors and a a charger on a ls1 i garuntee itd be more than 430kw at the fly
500rwhp the target....like this??
http://www.skylinesaustralia.com/forums/Au...ea-t208727.html
Make: Nissan Stagea Autech 260RS
Model: Stagea Autech 260RS
Milage: 115,000
Transmission: 5 speed Manual
Colour: Pearl white
Complied? Yes
RWC supplied? Yes
Currently registered? Yes
Price: $29,000 (edited by wolv to current price)
Contact: PM
Times up, missus wants a Prius. Hell of a way to reduce my carbon footprint.
97 mod. Excellent condition. Motor completely rebuilt at 100,000kms.
Engine.
RB26DETT
K&N pods
Z32 AFMs
N1 Group A turbos (RS581's)
TuneAgent manifolds
HKS dumps
Nismo front pipes
Trust PE2 exhaust
Blitz FMIC 102mm
Just Jap radiator
Greddy top pipe (rad)
N1 water pump
N1 oil pump
Oil catchcan
Tomei HG
CP pistons
REV I beam rods
Fully rebuilt bottom to top
New valves, stem seals etc
Minor head work
Tomei 264 cams
OK Giken cam gears
Greddy timing belt
Greddy timing cover
Relocated oil filter
Oil cooler
Tomei sump baffles
Sard 700cc injectors
Greddy rail
FPR
Bosch 044 pump
Splitfire coils
NOS heat plugs
Direct clutch twin plate (very heavy)
RS*R coil overs
Brembos with Ferodo pads
DBA5000 slotted rotors with gold hats (replacement rotors are cheap!)
BEO gold 17"
Greddy oil pressure guage (elec)
Greddy boost guage (elec)
Greddy pillar mount for the above
PowerFC
Greddy ProfecB Spec2
Blitz FATT timer
JVC HU with 3.5" screen
Im not sure if I have forgotten anything.
Car has run 11.9 in Darwin, unprepped track, street tyres at 35psi and 30deg heat (wind was blowing the wrong way too).
500.9rwhp, once again 30deg at 22psi. (wind was ok this time).
Regularly serviced, rarely driven as I have a Lib GTB wagon for work and the missus wants a Prius.
Great fun to drive, attracts very little attention. Manages to scare most people silly.
PM me for any questions.
Cheers
Ken
Edited by wolverine
great thread.
I'm thinking about a stagea myself. I've done a fair bit of research but can't seem to find running costs of a stagea.
I want to purchase one and just drive it as is, no modifications.
Are they higher maintenance than your average family car? If so is it possible to specify..
Parts: body & mechanical - readily available?
Reliability: They seem to have a fairly good name among enthusiasts, but i've noticed enthusiasts tend to have a blind love and overlook the times their car needs to be off the road..
I've read buyers guide etc.. but your thoughts would be good on general reliability - sorry to hijack the thread, but i didnt want to start another 'new to stagea' topic :-)
regards
David
great thread.
regards
David
I may be able to help with a few of these...
Running costs are a little bit higher than an aussie equivalent car (if one were to exist). However you get to drive a car that quite literally compares to cars worth more than twice as much....so they are still very good value!
I've only been driving my new M35 for a few days so cant offer much info on that, but I did own a series 2 stagea for 2 years, sold it earlier this year.
Maintenance-wise, its a matter of how much you want to look after your car. Not that different to any other car except that I'd recommend only using fully-synthetic oils and things like that.
My stagea didn't break down in the 2 years I owned it. There were a few issues when I first bought it - regarding the turbo and one rear shock absorber - but these are not a common fault and once fixed all was fine. The exhaust manifold can eventually crack/split, causing a loudish whistle when on boost (not the normal faint whistle you might here), but once fixed this doesn't normally show up again unless you're pushing it too far with mods...but once again, not a very common fault.
About the only common fault I have seen with stageas is a tiny rust spot underneath the passenger mirror. :(
Overall they are extremely reliable. However if you do need parts, a lot of the mechanical parts are shared with the skyline R33/R34's so you can be lucky with these. Worst case, you can import parts from Japan, but I've never had to do that (I've owned 4 nissan imports over 7 years and have never needed to import any parts from japan). There are a few wreckers here now stocking stagea parts too so for body panels etc you may still be in luck.
Fuel usage was around 13-14L/100km for me when my s2 was completely stock. I managed to lower this to 11-12L/100km through mods such as exhaust, apexi SAFC (+tuning) and some ignition timing adjustment, but if you want to leave it stock, the s2's are slightly more economical and more powerful than the s1's, and I've heard the M35's are also more economical and definitely more powerful than the s2's.
Look after the car and it'll look after you. Most of the ones that break, do so because they've been pushed too far (ie. modified or running too much boost etc) - which is why we dont include stuff like this as reliability problems. Mine was modified (160kw at all 4) and was rock solid.
Insurance will be a bit higher also, depending on your age and driving history. My M35 is $850 a year with a high excess. I had the option of $1200 with a $400 excess. I'm 26.
Hope that helps :O
Edited by pixel8r
I have to agree with pixel8r with every he said
As you have already read the buyers guide - you would have read the common things to find when looking at a Stagea.
I've got a S2 RSFour V Prime Edition (electric leather seats and "woodgrain" interoir) and i've had it for 10 months and hasn't skiped a beat. I just have to do some minor repairs (change over front castor bushes) and do some mods
If you intend to keep it stock and well maintaned, then car will be relaiable like every other car on the road IMO.
in addition to looking for parts - always check the parts classified here on SAU - people are always selling...even ebay - you may get lucky (I saw someone selling SK's suspension kit for $800 not that long ago - wish i had the money).
Insurance just shop around...there is a thread on here about insurance and how much they got it for (I went with Just Car - $1050 with $500 excess, rating 1, all my mods covered aswell and i'm 26)..mind you this is my real first car and first time i've got insurance
Edited by BigDirtyJase
barra 240T into a stagea.... opinions??? ;)
Turbo is on the opposite side of the engine to the RB, so that is something you'll have to think about. However, as mentioned the 1JZ has been transferred into a Stagea before which also has the turbo on the drivers' side, so it's not impossible.
think itd be possible to do a twin turbz 2j into a cressy?
That's been done plenty of times. Even better, some people leave them looking grandpa-spec outside!
They were available like that in Japan direct from Toyota, at least in 1JZ form.
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
