  • Replies 40
whats that going in?
went all out and got the v88 :laugh:
Yeah...its going to give me all the features i need...the cooking model Apexi Power FC was holding the car back from performing to its optimum. Flat shift, anti-lag, logging etc...is needed to go to the next level...free revving the car off the line with zero boost is now a thing of the past. Its going to be a handfull!
It doesnt look as pretty as a motec :laugh:
Whats the little green circuit board i spy just above the ECU itself?
plug in adapter?
yes its a nissan pin-out plug....will save me a lot of time on installation.
this ecu combined with the 1100hp turbo upgrade, fully optioned PPG straight cut dogbox and a slightly lighter car should give me the hardware to chase the ANDRA class record...ive just got to get the skills (balls) to drive it to its potential.
Edited by DiRTgarage
looks sweet.
reckon the launch control etc will go better?
what power / time you expecting now?
why go this one? value for money or you know the distributer or features or what? a car of your calibre would have had a few options im guessing?
boost off the line is needed to get the 60's into the 1.3's (my best is 1.41) to run the low9's-high 8's
should be good for 900+hp at the tyres and with 3000lb's should be a high 8's car (without NOS)
i went with this one as its the best on the market $ for performance than any ECU, it performs as good as a MoTeC M800 without the huge pricetag. Its features, processor speed etc is equal to MoTeC and Ray Hall's after sales service and technical back-up is second to none...it was a no-brainer really. Mark Jacobsen doing the tuning is another bonus for me...in my opinion he is one of the worlds best GTR tuners.
if i can run this with success then it will give others confidence that they can run one too. I help market this product because i believe in it not because i make money from it. I have always given free advice on here with products ive found to be good and bad...if its not up to the task, ill definately say so. Stay tuned :laugh:
Awsome, grats on your new goodies!
i heard they cant be used for r34s? is this true?
( i must have looked at a old mag issue)
all the Vi-PEC ecu's (V44 plug-in, V44 wire in and V88 wire in) can be used in an R34...except with an auto model you must retain the factory ecu to run the auto and use a wire in V44 or V88 to control the engine
Looks a lot like LINK ecu from outside. + the packaging is similar.
looks can be decieving
Can you guys get it through your head this is not a rebranded Link g3 or other ecu...
Alright i have read on there that the vipec is just a re branded link/adptronic(SP?)
i got this from the evo site by ray hall himself
"Hello Everyone,
When I stopped selling, promoting and supporting the Autronic product, I went looking for a replacement, as many of my old Autronic dealers wanted to stay with what ever I was selling. After some months of negotiations with a few company's I settled on one of them. They agreed to build me "new" ECU under by own brand name. They also were willing to build them to my specifications. After many years with Autronic I knew exactly what I required based on years of requests from customers. As many of my Vipec dealers had only worked with Autronic ECU in the past, it was important that the ECU used the same fuel control stragtery software, had QuickTune (Autotune) and used many of the same keystrokes.
The Vipec is not a rebadged Autronic or LinkPlus G3. It is a totally new range of ECU. We plan to make a range of plugin ECU for the EVO1 to 8 and the EVO9. The plugin for the EVO4 to 8 will be available next week. This is based on the V44, with extra injector and auxiliary outputs, plus more analog and digital inputs. It is what some have called a V64."
A friend of mine here in Newcastle who owns Mastertune Engineering (Lincoln Russell) has done a lot of the development of this product and i know how much work has gone into it to get it up to the performance level its now at....it may share some components of the Link but that is all. He was also involved in the development of the Autronic SM4 and rates this product far superior than it...the SM4 is an awesome product so thats a big call for him to make...but he has voted with his feet and upgraded the ECU in his VL 4WD RB26DETT...yes a VL with all GTR running gear to a V88.
I have heard it a few times, but i won't belive that Lincoln would say anything is better then Autronic unless i heard it from his mouth, and I did.
Made me feel that i should give back this SM4 and get one too :ermm:
    • That still isn't a lot to go on. I don't have a Y50 Fuga Head Unit wiring diagram. I can say that a lot of nissans of that age shared head unit plugs, so if you are in Australia something like this would probably help: https://aerpro.com/app091# You plug that into the car loom, then either plug the head unit ISO into that (if it has ISO), or you buy and ISO adapter harness that you wire in. Bit of stuffing around, but once you have ISO its easy to change things in future.
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
