yea i have gq patrol but couldnt find a base, so i dicded a landrover will do the job
ahaha well i kinda borrwed your trailor:P
im in the progress of making the trailor one of those half closed ones
should be different :D
no worries man, i just cut/chopped/cropped my stuff from elsewhere anywayz :)
just be careful on the pixel forums, they go spaz if you dont credit who ever you pinched it from.
no worries man, i just cut/chopped/cropped my stuff from elsewhere anywayz :D
yea i know i posted it in the WIP part nd got blasted
im like dude chill its work in progress im still channging stuff on it --- not comment
kinda gay how they have a sook about that stuff but
Just done up an R31 to look like my car... White R31 GXE S1, s3 tail lights, lowered, exhaust, XXR 002 rims, d1 spec wheel nuts, painted grill, clear indicators, rubber front lip. Its in my Signature.
Edited by NISMØ
Pretty please does someone want to do mine?
sorry if this is too many / too big photos, just figure its better safe than sorry if you want to see details..
ignore missing right front indicator, took these snaps yesterday as a break from wiring in new indicators :P
many thanks to anyone who has a go!
  • 1 month later...
anyone want to give my stagea a go?
"lightning yellow" (same as r34's)
dayz front bar with carbon bit in the middle
r34 front brakes (blue)
18's (but put whatever you think will look good, maybe lenso d1r lookalikes)
minus the mud too lol
Edited by pipster11
  • 3 weeks later...
i've done a fair few, i can't do bases for shit but i work on them and modify them a fair bit...
here's a couple i've done (various cars)
S14 Sil80
Strobed for an avatar
R33.4
  • 4 months later...
    • Jack the back of the car up, pull that wheel off, pull that sensor out, and put a bore scope into the hole to inspect the outer casing, see if anything looks damaged before you pull the whole thing apart.
    • Ergh... So I pulled the speed sensor out again and the tip was shiny so I think it's rubbing the bearing. The bearing contains the magnets for the speed sensor so I think when the first sensor broke it damaged the magnet ring on the bearing.  This is just a Google image, but there is a hole going to the bearing. So when the tip broke off the old sensor I'm guessing it fouled the bearing... As the magnet is only protected by a plastic cover it would be easy to damage it. So I guess I'm doing a bearing again.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
