spot-on...its main use is not to impress the derro's at Summernats but to cool down after the antilag is used.
i also use it on hot summer days when driving in sydney traffic, because the oil cooler and 4" core intercooler is in the way the water temps get very high and the cycle idle actually keeps the temps around 5 - 10 deg cooler.
  • Replies 67
lol.. see the bogan jumping for cover? i decided against doing a burnout there, I could not have anything happen to my car just to prove something to bogans... I am saving it for power cruise instead.
Don't you feel guilty? if you still have a cat, it must be rooted from all that unburned fuel.
And dumping all that unburned fuel into the air sucks for everyone else .. & for what?
u do it in sydney traffic? what can justify that apart from having a public wank?
god damn. the first time i have actually been jelous of another type of ecu over the PFC. sounds like a good idea in theory and id do it just for the funky idle. ricer from wayyy back....
on that note. whats it cut out, fuel and spark or just spark. i cant imagine it would just cut out spark... wouldnt it wash the bores out and foul the plug up? or not so?
thanks for your input Bob Brown.
Its a catch 22 really...unburnt fuel evaporates benzine and hydrocarbon into the atmosphere...burnt fuel releases carbon di-oxide carbon monoxide etc.
6 of 1...1/2 dozen of the other.
not really. the point of a cat is not just so you don't have to clean your bumper, and the point
of all that plumbing at gas stations, is not just for show. CO2 isn't poison, it isn't great, but whatever.
EPA regulations aren't just a revenue raising idea either.
However unburned hydrocarbons are much worse. Not 6 of one and half a dozen of the other at all.
and for NO REASON AT ALL in traffic, rather than to win races on a track, seems to me to be the same
morality as cutting down trees because they spoil your view, or pouring oil down a street grating.
Just needlessly anti-social, really.
he said it was to help his car from overheating in extreme conditions (which we have had lately) in traffic...did you not care to read and understand that part?. Guilt-Toy every friday afternoon has to make his way from Sydney through peak hour traffic to head up to Newcastle...a journey that lately has seen him stuck in traffic for hours!
You are a little hypocritical as only the other day you were enquiring about how much more power you make running leaded fuel!!
http://www.skylinesaustralia.com/forums/Pu...16-t253466.html
no tree hugging going on in there ? no crack at me for selfishly destroying the planet by running leaded fuel in my car...at the very least if you are having a soapbox rant please be consistent. Read the thread title...what did you even come in here for anyway?
unburnt fuel? ohhhh Mr Internet Mechanic....... man... rotatational idle works by cutting fuel to keep the revs down.. it is running lean not rich. rofl
the cooling happens because of all the fresh air getting pumped in and out of the engine not the excess fuel. >_<
and i thought my last post may have given him a rap over the knuckles...
that one has cut his whole hand off and shoved it up his arse!
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
