Hey,
I bought a nismo gearknob probably bout 8 months ago and its gone funny. The chrome has basically rubbed off leaving a brass kind of colour over it. Just wondering if anyone else has experienced a problem with them?
I bought it off ebay yeah but it came in a genuine nismo box so I think it is genuinely nismo...
I'll take pics later.
Cheers.
https://www.sau.com.au/forums/topic/244993-nismo-gear-knob/
Hey,
Cheers.
Yes, mines gone funny too, keeps doing Will Farrell impersonations !
https://www.sau.com.au/forums/topic/244993-nismo-gear-knob/#findComment-4266340
ive got a GREDDY one thats done the same thing. genuine GREDDY GREX one. http://www.sp-power.com/catalog/images/KNO...UE%20GREDDY.jpg
this one^^ was black chrome but black is wearin off and jus chrome showin now. only had it for a few months. first some like thin plastic rubbed off then the black. still looks good.
https://www.sau.com.au/forums/topic/244993-nismo-gear-knob/#findComment-4266790
Your nobs worn.
Sorry.. Couldnt help myself
maybe you've been stroking it to much and its wearing out!
jk :P
I've noticed with the NISMO carbon fibre style ones they tend to fade and go a funny colour, I went with the black chrome which looks heaps better
:P
Stop play with your knob while driving...
Ok its been said.
I just got the stock gear knob and its still good.
https://www.sau.com.au/forums/topic/244993-nismo-gear-knob/#findComment-4267592
i got the black metal nismo one.
mines all faded at the top, its gone a bit white lol....
happens over time, cause of sweat, and oil on your hand, and on a hot day dont even think about touching it.
thinking of getting the leather one now.
https://www.sau.com.au/forums/topic/244993-nismo-gear-knob/#findComment-4267604
:P
Ok its been said.
+1 for stock hear knob
pm me if you wants to buy 1
https://www.sau.com.au/forums/topic/244993-nismo-gear-knob/#findComment-4267875
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
