Driver Dynamics Beginners Drift Day Sandown Saturday 17th January 2009
If you’ve always wanted to have a go at drifting on the circuit, but didn’t want to attend a fully blown drift day, then we have a course that will suit you perfectly.
To be conducted at Sandown on 17th January 2009, this day is aimed at drivers who want to have a lot of fun and learn plenty about drifting from Australia's best professional drifters including Adam Newton and Luke Fink.
The exercises will be conducted on wet roads to keep the speeds down and minimize wear and tear on your car.
The cost for this course is $195.00 including lunch and refreshments.
We’re taking bookings now, so if you’d like to attend give us a call on 1300 652 693
  • Replies 147
Posted Images
eek...this should be fun. how is the track gonna be set up? diff groups diff sections? learning how to link corners? semi-high speed corners? how close are the barriers again?...lol
+1 More info on the day please, Wet track ie. Large Skid Pan with cones?
who in their right mind would drive an auto sk.....oh....
I've organized early skidpan days in 2003, and there's some auto cars attended, including a benz, which are purrfectly fine for drifting.
It's the driver who drifts, not the car. If you got skills you can even drift a rickshaw if you really try hard...
yeah but basti has only had exp driving these things, and well i dunno man......skyline is a whole new ball game :)
will a tiptronic with foot brake (not hand brake) will cut it?
well if u block, by putting a chunk of wood or something there, the release lever so it'll always release the hand brake when ur foot's off it shud work.
so i'm guesing this is gonna happen in the car park? how much track time each?
is this the same as a cams event so needed is a day's cam's license and gear would be required such as adr helmet long sleeve's and closed footwear ?
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
